5 members (lord-richfield, itsfrank666, RichardV6, Graham, G4FUJ, Alanv60), 319 guests, and 38 robots.
+8Rich 71
Adam12 69
John V6 57
9,215 Registered Users
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,371
Posts813,488
Members9,215
I am preparing to change the gearbox oil in my 2011 3 litre S2 Roadster and wonder if anybody has done this task themselves. The reason for asking is that when I opened up the inspection hatch in the drivers footwell there was no gearbox filling point. Looking down the passenger footwell there were two inpection hatches so I drilled out the rivets and opened the most promising looking one. There appears to be a filling point about 50mm infront of the inspection hatch. It is going to be a real pain to firstly unscrew the filler plug (which appears to be a big oversize allen key job) then fill the gearbox with oil down a funnel and tube.
Anybody done this job themselves and can you confirm that the filler is indeed the one in the passenger footwell. I am told I have a Ford gearbox in the S2.
Any helpful tips from those that might have done this task would be helpful. If the task defeats me due to a lack of powered ramps I need to explain the task to my friendly local garage
AndrewD
2023 Lagoon Blue Plus Four
2019 Jaguar F Type
2024 Ford Puma ST Line X
Have you checked DaveW's How to in the Classic Morgan section ?
http://www.talkmorgan.com/ubbthreads.php/topics/30581/Dave's_Classic_Morgan_How_To..#Post30581
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Yes I have been in contact with DaveW. He does not have experience of the S2 gearbox.
AndrewD
2019 Jaguar F Type
Buy a cheap oil pump and do it from underneath, I did it last year and was easy. I do have a lifter though but can be done on car ramps.
Jim.
E
E
Jim.
Jim
I have failed so far to find anything at less than £100 to get gearbox oil into a car when on my lift. Have bought a few things that leaked.
Have you found something to pump gearbox oil that does not leak at a reasonable price yet..
Jim
Interesting you have done a S2 gearbox oil change. Can you confirm the filler is indeed on the passenger side and did the filler and inspection hatch line up! I think getting the oil in with tube and funnel might be ok but trying to undo the filler plug might be a sod.
AndrewD
2019 Jaguar F Type
Perhaps a bit drastic but have you considered cutting a better access hole? Shouldn't be a major problem unless there is a danger of damage to parts behind the tunnel. Screwing/rivetting a cover for the hole is straight forward. Beware of heat/sound insulating material behind the tunnel though.
I bought a cheap plastic pump from machine mart £20 It is a hand pump. Bit tedious but it works.
Originally Posted By Bluey Roadster
Jim
Yes the filler is on the passenger side just above the drain plug. You can reach it with a plastic pipe to fill it from underneath if you can raise you car up of the floor. I used a plastic hand pump from machine mart £20 it has a loop with it that can be hung in the filler whole. Fill it until it overflows, it was around 2 litres I think. I used millers gl-5 ep 75w 80 mineral, this was recommended buy Phil at Brands Hatch Morgan.
Regards Jim.
Jim thanks for that. I have ordered up some Morris Lodexol FS75W90 and some pre mixed Morris diff oil.
AndrewD
2019 Jaguar F Type
