2 members (Saxonian, +8Rich), 392 guests, and 42 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
#441008 05/04/17 12:02 PM
carchap Offline OP
Hi Folks,
Does anyone know if there is fix to prevent water coming in over the windscreen between the hood material and the windcreen frame when using an old style mohair hood?
I think I saw a mention of a mod to help.
I may not ever drive in the rain but I would like to know if I ever need to!
I did try to use the search field against key words but didn't find the thread.
Cheers, Giles
2011 Sport Sand Plus 4, 360 Modena, 718 GT4, RC200t
Giles,
I would think that Dave W has this covered somewhere in his comprehensive "how to" posts.
Reg
Neoprene is the fix. If it's a nine stud traditional hood, (older versions had ten), use contact adhesive to glue a strip of 4 mm standard density neoprene just above the lift the dots. It may also need a thinner profile at the lower edge of this. Some neoprene is self adhesive and this will also do it.
What was the original Prene like if this is the Neo-prene?
Best Regards
Lang may yer lum reek
Originally Posted By carchap
Hi Folks,
Cheers, Giles
. My series 1E Type d/h leaked from new - a thick smear of Vaseline cured. However not to say it will work on the Mog ,but worth a try eh!
Stingmog
According to the works of Brunel, I suspect that it (prene) - was leather. Shades of the atmospheric railway..................
So an equally alluring smell.
carchap Offline OP
Thanks for the suggestion DaveW. You say 4mm, do you know the w/d/h numbers of the neoprene?
Would you have a photo?
Cheers, Giles
Giles.
I cut mine from a 4mm thick roll. The length is the width of the hood and the depth is around 2 cm but this is not critical. There's a neoprene guide in my 'how to' section in Classic Morgans. Alternatively I source self adhesive strip from C O H Baines.
carchap Offline OP
Excellent, thank you.
Cheers, Giles
Another way is to stick a length of "P" section draught excluder along the top of the screen surround - its self adhesive - the hood then compresses it when attached and stops moisture coming over the top
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
