12 members (mph, John07, BLUE+4, asterix, Graham, G4FUJ, Grumpy2, TomS, DJC, Vansrv6, GrumpyPa, B3MOG, Sir Percival),
314
40
Topics48,364
Posts813,336
Members9,215
Posts: 32 |
Hi Folks, Does anyone know if there is fix to prevent water coming in over the windscreen between the hood material and the windcreen frame when using an old style mohair hood? I think I saw a mention of a mod to help. I may not ever drive in the rain but I would like to know if I ever need to! I did try to use the search field against key words but didn't find the thread. Cheers, Giles
2011 Sport Sand Plus 4, 360 Modena, 718 GT4, RC200t
Posts: 5,366 Likes: 15
Posts: 5,366 Likes: 15 |
Giles,
I would think that Dave W has this covered somewhere in his comprehensive "how to" posts.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Neoprene is the fix. If it's a nine stud traditional hood, (older versions had ten), use contact adhesive to glue a strip of 4 mm standard density neoprene just above the lift the dots. It may also need a thinner profile at the lower edge of this. Some neoprene is self adhesive and this will also do it.
Posts: 6,829 Likes: 59
Posts: 6,829 Likes: 59 |
What was the original Prene like if this is the Neo-prene?
Posts: 288 |
Hi Folks, Does anyone know if there is fix to prevent water coming in over the windscreen between the hood material and the windcreen frame when using an old style mohair hood? I think I saw a mention of a mod to help. I may not ever drive in the rain but I would like to know if I ever need to! I did try to use the search field against key words but didn't find the thread. Cheers, Giles . My series 1E Type d/h leaked from new - a thick smear of Vaseline cured. However not to say it will work on the Mog ,but worth a try eh!
Stingmog
According to the works of Brunel, I suspect that it (prene) - was leather. Shades of the atmospheric railway..................
So an equally alluring smell.
Posts: 32 |
Thanks for the suggestion DaveW. You say 4mm, do you know the w/d/h numbers of the neoprene? Would you have a photo? Cheers, Giles
Giles. I cut mine from a 4mm thick roll. The length is the width of the hood and the depth is around 2 cm but this is not critical. There's a neoprene guide in my 'how to' section in Classic Morgans. Alternatively I source self adhesive strip from C O H Baines.
Posts: 32 |
Excellent, thank you. Cheers, Giles
Posts: 3,425 Likes: 26
Posts: 3,425 Likes: 26 |
Another way is to stick a length of "P" section draught excluder along the top of the screen surround - its self adhesive - the hood then compresses it when attached and stops moisture coming over the top
Cheers!
