5 members (+8Rich, Aeromax51, vincentvg, tezzer, Alan Patterson), 347 guests, and 85 robots.
Topics49,848
Posts837,402
DazMog, The Impaler, tlchzj79
Page 3 of 4 1 2 3 4
Hamwich #453791 07/06/17 07:04 PM
Originally Posted By Hamwich
Originally Posted By jbk
Good luck with the repair Stewart, while you are at it, you might want to consider also reinforcing your lacing by criss crossing underneath the diaphragm with heavy fishing line (at least 200lb bs) as a belt and braces job? Might last a bit longer spreading the load a bit.
As an alternative to fishing line, you might want to try nylon strimmer line, that's what I used and it worked very well.
Top suggestions
I was wondering what to use to lace up - I was going to use a couple of bootlaces
I will also pop into my upholstery foam suppliers on the way to work tomorrow and get another piece of foam to go inside as the seat could do with a bit of extra plumping
The chap who had the Mog before me was on the large side and the foams do compress and detierate
Stewart S #453806 07/06/17 07:41 PM
I have experienced the same sort of split on My 2000 seats. I bought a new diaphram from a Morgan Dealer. Apparently this is a common failure.
Button
Button #453814 07/06/17 08:00 PM
It's strange that the split occurred in a neat straight line where the mesh is reinforced with the rubber
Stewart S #453822 07/06/17 08:18 PM
This topic sounds like a Noel Edmunds program grin2
Stewart S #453939 08/06/17 12:08 PM
Stewart, paracord would be good for lacing up the seat. Somewhere like B&Q sell various ropes/cord/chain/wire.
sospan #454066 08/06/17 10:28 PM
Being a canoeist and into bushcraft, I've got reels of the stuff but I'm going to use a thin sailing sheet - 4mm braided polyester so there is absolutely no elastication
Stewart S #454549 11/06/17 06:57 PM
Well finished the seat tonight
I forced another 25mm thick firm foam bolster into the seat and laced it up
Didn't go quite to plan as a couple of the eyelets ripped out of the rubber so it's not the neatest job but certainly done the trick
Finished off with some fly fishing line lashed under just in case
All nicely firm and plump
Stewart S #454567 11/06/17 09:14 PM
Black Rat
Black Rat
Fly fishing line...............is this the start of another fish joke ? speakno
Keith
2013 narrow bodied + 4 Ruby.
I also noted that Stewart has stated that he is into canoeing and bushcraft!
Maybe a change of site name to Hiawatha?
Bud
4/4 "Stanley"
Stewart S #454615 12/06/17 08:39 AM
Before the seat was padded that should bbe Lowerwatha!
I hope the flyfishing line was floating type not fast sinking! ooo
Page 3 of 4 1 2 3 4
