0 members (),
199
89
Topics49,847
Posts837,389
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Good luck with the repair Stewart, while you are at it, you might want to consider also reinforcing your lacing by criss crossing underneath the diaphragm with heavy fishing line (at least 200lb bs) as a belt and braces job? Might last a bit longer spreading the load a bit. As an alternative to fishing line, you might want to try nylon strimmer line, that's what I used and it worked very well. Top suggestions I was wondering what to use to lace up - I was going to use a couple of bootlaces I will also pop into my upholstery foam suppliers on the way to work tomorrow and get another piece of foam to go inside as the seat could do with a bit of extra plumping The chap who had the Mog before me was on the large side and the foams do compress and detierate
Posts: 1,943 |
I have experienced the same sort of split on My 2000 seats. I bought a new diaphram from a Morgan Dealer. Apparently this is a common failure.
Button
I have experienced the same sort of split on My 2000 seats. I bought a new diaphram from a Morgan Dealer. Apparently this is a common failure. It's strange that the split occurred in a neat straight line where the mesh is reinforced with the rubber
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
This topic sounds like a Noel Edmunds program
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Stewart, paracord would be good for lacing up the seat. Somewhere like B&Q sell various ropes/cord/chain/wire.
Stewart, paracord would be good for lacing up the seat. Somewhere like B&Q sell various ropes/cord/chain/wire. Being a canoeist and into bushcraft, I've got reels of the stuff but I'm going to use a thin sailing sheet - 4mm braided polyester so there is absolutely no elastication
Well finished the seat tonight I forced another 25mm thick firm foam bolster into the seat and laced it up  Didn't go quite to plan as a couple of the eyelets ripped out of the rubber so it's not the neatest job but certainly done the trick Finished off with some fly fishing line lashed under just in case  All nicely firm and plump
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
Fly fishing line...............is this the start of another fish joke ?
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Fly fishing line...............is this the start of another fish joke ? I also noted that Stewart has stated that he is into canoeing and bushcraft! Maybe a change of site name to Hiawatha?
Bud 4/4 "Stanley"
Before the seat was padded that should bbe Lowerwatha! I hope the flyfishing line was floating type not fast sinking!
