8 members (mph, MartinB60, Morganmike, DMC1904, DJC, Graham, G4FUJ, John V6, nick w),
293
43
Topics48,364
Posts813,337
Members9,215
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
I was curious as to why the vacuum pump had 2 ports. I found this on the web, which explains all. Exhaust flap valve...I guess on a cross pipe linking the LH and RHS exhausts, the flap will close when in sport mode, or something. Any BMW expert here? This is the front of the engine in an Aero chassis, the pump is upper left. Complicated, isn't it? Not at all surprised the bonnet, front bodywork and O/S wing had to come off.
Think Williams have taken more than the wings & cowl off
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Incredibly complex engine.... I am always slightly boggled by who designs these things!
+8 4.8
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Pleased to hear it is fixed.
Richard 1976 4/4 4 Seater
Think Williams have taken more than the wings & cowl off And done a LOT of cleaning and polishing of bits not normally seen...almoist like new!!
Posts: 6,538 |
Great news Peter - delighted for you.
Hopefully not to severe a hit on the wallet!!
And your smiles returned!!
Neil
Posts: 246 |
Peter, thanks for the update. I've added this to my "ones to watch list", as I did the issue on the potential failure of side-exhaust bracket. Sadly, that one I have experienced, in-spite of taking mitigation actions.
Time will tell on Vac Pump.
J. Neil
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
I have seen a couple of cars with exhaust flaps. They were to divert the flow from the silencer normal route ( usually not straight) to a straight through alternative pipe. Purpose was to improve flow and noise. Not sure if a BMW is set up like that though. Some car modders fit a flap valve to dump the ehaust out before the silencer box to the underside, cutting out a big part of the system.
Yes, the C43 has three valves... One opens or closes a transfer pipe between the two sides and the other two divert the exhaust away from the rear silencer on each side. This happens only in "Sport +" mode which, the handbook suggests, is not for road use...
