6 members (DCH, B3MOG, JohnHarris, Barry M, tezzer, linklaw), 348 guests, and 79 robots.
Topics49,848
Posts837,404
DazMog, The Impaler, tlchzj79
Page 42 of 46 1 2 40 41 42 43 44 45 46
ShaunD #479561 29/10/17 04:19 PM
The dealer needs to check all the wiring.
Section x section - its a painstaking job which might be why they are just scratching their heads!!
Neil
ShaunD #479595 29/10/17 08:39 PM
CBM Offline
This has got me wondering whether one ought to get a battery charger pack just in case. Advice/recommendations?
ShaunD #479619 30/10/17 06:02 AM
Had a similar problem,would run good for miles then die and not start then later would be fine, start no problem and run till it stopped again. Turned out to be a earth line from the fuel pump to the common earth block connector.
ShaunD #479627 30/10/17 07:20 AM
ShaunD Offline OP
Thanks for the further messages, all. I will be passing on all suggestions as to what it might be to my dealer this morning.
ShaunD #479631 30/10/17 07:36 AM
Good luck with this...
ShaunD #479641 30/10/17 08:42 AM
ShaunD Offline OP
Cheers. Have passed on Elcyd’s message in full to my dealer as it does sound like he had exactly the same problem. 🤞🤞🤞
CBM #479643 30/10/17 08:56 AM
Is one of these what you were considering? Not sure how this would help ShaunD
http://www.autoexpress.co.uk/accessories-tyres/92728/best-mini-jump-starter-packs-2017
I think there was a thread discussing this.
Tim
ShaunD #479714 30/10/17 04:38 PM
ShaunD Offline OP
Latest update: my dealer has checked the car all over and still can’t find anything wrong. The ECU is showing no error codes (as before). They took the car for a 50 mile spin and, of course, it performed flawlessly and they were not able to replicate the problem. Typical! The car is going to be returned to the factory tomorrow morning to see if they can work out what it is. Hopefully, Mark and his team will be able to sort it.
ShaunD #479719 30/10/17 05:10 PM
Least should be run in by the time you get it back!!!
ShaunD #479734 30/10/17 06:31 PM
Could it be the fuel cut out switch, mine petered out a few weeks ago, the AA took it to my supplying dealer, he in turn rang me the next day and asked if i had been over a pothole or across a rough track as the fuel cut out switch had been triggered, i assured him i had'nt done either, but he was convinced that was the problem, as i was going on holiday that day i arranged for my son o collect it the next day, he duly collected it and 2 miles later it broke down in exactly the same way, the dealer collected it and this time they fitted a new fuel cut out switch and i am pleased to say no further problems so far.
0000oooooooo
