2 members (Mauli, Hamwich),
322
41
Topics48,341
Posts812,981
Posts: 31 |
I have most if not all available handbooks on the Standard Special engine but cannot find any information on the purpose and other connection point of a copper tube approx 3mm ID with male end fitting that comes from(or goes to) the female threaded port in the underside of the inlet manifold. Only one drawing shows this line end but not where it goes to.
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Could it be for cold start to the carb or some sort pf crank case ventilation for early emissions controls?
Where is WA are you Brian?
Richard 1976 4/4 4 Seater
Posts: 52 |
G'day Brian Could it possibly be the suction tube for the vacuum wiper system. I do not have access to my reference books this weekend as we are at our daughters by Palmerston North but will check when I get back perhaps on tuesday. Doug Deep deep down under.
Posts: 31 |
thanks for replies and will recheck but doesn't appear to be either of those possibilities. Richard I'm in South Perth but the car is down with Paul my miracle cabinet maker friend for the woodwork at Hopelands near Rockingham but will be coming up to Dave McLaughlin in Bibra Lake soon
Posts: 125 |
Drain for a flooded intake manifold to stop fuel filling cylinders in the event of a stuck float
Posts: 31 |
thank you - much appreciated
Posts: 1,148 Likes: 18
Posts: 1,148 Likes: 18 |
yep agaree with the fuel overfill or drain it is on ours...you need a pipe venting under the car to ground! Just like the oil breathers on the block. 2015-04-07 08.12.23 by Robert & Ali Davies, on Flickr
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
thanks for replies and will recheck but doesn't appear to be either of those possibilities. Richard I'm in South Perth but the car is down with Paul my miracle cabinet maker friend for the woodwork at Hopelands near Rockingham but will be coming up to Dave McLaughlin in Bibra Lake soon I am north of the river in Nedlands....
If you are in western austarlia our series 1 4/4 sepent much of her life there withIan Sedgewick one of the founders of the morgan club in WA we have the black swan river car badges if you want one ?
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
yep agaree with the fuel overfill or drain it is on ours...you need a pipe venting under the car to ground! Just like the oil breathers on the block. 2015-04-07 08.12.23 by Robert & Ali Davies, on Flickr I like the test bed, did you build that? I don't know anything about these old engines but if the pipe attached to the manifold is open to drain, doesn't it affect the manifold vacuum or does it have a tap or one way valve? I'm curious. BTW, I love the Flickr link to the rebuild.
Bob
