6 members (Laurens, Montegue, Bitsobrits, TalkMorgan, jbk, Luddite), 285 guests, and 82 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,459
#485292 26/11/17 02:20 AM
brianw Offline OP
I have most if not all available handbooks on the Standard Special engine but cannot find any information on the purpose and other connection point of a copper tube approx 3mm ID with male end fitting that comes from(or goes to) the female threaded port in the underside of the inlet manifold.
Only one drawing shows this line end but not where it goes to.
Could it be for cold start to the carb or some sort pf crank case ventilation for early emissions controls?
Where is WA are you Brian?
G'day Brian
Could it possibly be the suction tube for the vacuum wiper system.
I do not have access to my reference books this weekend as we are at our daughters by Palmerston North but will check when I get back perhaps on tuesday.
Doug
Deep deep down under.
brianw Offline OP
thanks for replies and will recheck but doesn't appear to be either of those possibilities.
Richard I'm in South Perth but the car is down with Paul my miracle cabinet maker friend for the woodwork
at Hopelands near Rockingham but will be coming up to Dave McLaughlin in Bibra Lake soon
Drain for a flooded intake manifold to stop fuel filling cylinders in the event of a stuck float
brianw Offline OP
thank you - much appreciated
yep agaree with the fuel overfill or drain it is on ours...you need a pipe venting under the car to ground! Just like the oil breathers on the block. 2015-04-07 08.12.23 by Robert & Ali Davies, on Flickr
Triumph Herald 1969 13/60
Morris 1970
I am north of the river in Nedlands....
If you are in western austarlia our series 1 4/4 sepent much of her life there withIan Sedgewick one of the founders of the morgan club in WA we have the black swan river car badges if you want one ?
Morris 1970
I like the test bed, did you build that?
I don't know anything about these old engines but if the pipe attached to the manifold is open to drain, doesn't it affect the manifold vacuum or does it have a tap or one way valve? I'm curious.
BTW, I love the Flickr link to the rebuild.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
