2 members (+8Rich, Mr K),
382
98
Topics49,859
Posts837,483
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
My clutch return spring on my last Mog broke within weeks of me buying it
I bought a new one from Rutters but never got round to the challenge of fitting it Apparently winding the old off and the new one on is a finger and wrist breaker
So I left it broken and drove it for 3 years without any issues
Clutch returned fine without it
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
Clutch returned fine without it Ah you should have used the Octopus method
Posts: 44 |
- UPDATE -
Today I finally replaced the clutch pedal spring and I can confirm that this job is really greasy and was quite fiddly, but in the end successful. By this occasion I also replaced the worn pedal rubbers. Thanks again for your support.
Karsten
2010 Teal Roadster Sport V6
- UPDATE -
Today I finally replaced the clutch pedal spring and I can confirm that this job is really greasy and was quite fiddly, but in the end successful. By this occasion I also replaced the worn pedal rubbers. Thanks again for your support. Well done How did you get on winding the new spring on?
Posts: 44 |
In my 2010 built Roadster Morgan fortunately changed the design of the pedals so that I was able to simply slip the spring on the tube at the bottom of the pedal.
Karsten
In my 2010 built Roadster Morgan fortunately changed the design of the pedals so that I was able to simply slip the spring on the tube at the bottom of the pedal. Oh that’s good, I didn’t realise the pedal assembly had changed
Posts: 8,675 Likes: 490
Posts: 8,675 Likes: 490 |
And another update too...
At a very recent Factory visit, all the Roadsters in build I could find (3) had NO clutch return spring fitted
Posts: 44 |
At a very recent Factory visit, all the Roadsters in build I could find (3) had NO clutch return spring fitted Hmmh, then it seems that I did an unnecessary repair job 😃
Karsten
Karsten, I think you have done the right thing re-fitting yours on the 3.0 model
But I still can't get a tech answer to why some of the latest 3.7's have none
Posts: 44 |
Jon, I did it and it works quite well. Bur ih seems that this spring is really not a absolute necessarry thing...
Karsten
