4 members (BertL, Craig Jezz, JMcL, mph), 347 guests, and 53 robots.
Topics49,846
Posts837,381
Page 3 of 3 1 2 3
Thats the way I have to do my mohair hood (it shrank slightly after reproofing). Usually with a pair of pliers to help fasten the last few turnbuckles.
The correct way is to attach the rear, pull over erect hoodsticks then fasten lift-a-dots to windscreen. However, do be careful, you can crack the windscreen.
I recommend some of John Taylor's over-centre hood swivels as Steve suggests. These allow the hoodsticks to sit a little lower while fastening the hood, then can be swung around to tension the hood. Can't be fitted to cars with bench seats (like my '76) though.
Cheers,
Further to my question at 10:48, Has ayone any experience of the "Hood Frame "Swivel Pivots"" advertised on the website Morganhoods.com??
Go for it. As Graham says. We use them all the time, without them it is hard work.
http://www.morganhoods.com/id70.html
Thanks Graham and A11OGE I shall order them immediately!
No problem thumbs
Originally Posted By A11OGE
Assuming you have a the original hood design. It is like erecting a rig tent frown
1. Erect the hood bars
2. Clip the hood to the windscreen first.
3. Then attach to the rear.
If this is impossible/hard, then it maybe because the hood is very tight against the hood bars. If this is the case I suggest you invest in a pair of Hood Swivels as advertised in Miscellany.
make sure you fasten the centre lift the dot first on the windscreen - reduces the chance of breaking windscreen.
if the hood hasnt been used for a while it can be tight. try taking it indoors to warm up for a bit!
Managed to fit the hood last night without even having to take it indoors. A case of perseverance and not being a whimp.
(Iv'e been driving citroens too long and have no strength left)
BTW its much more fun to drive than I was led to believe. At least my wife will now also accompany me when it rains now!
One thing I've noticed - the Swivels cause bruising to the bum when we aged struggle to get out the car! sick2
rofl
Chris, I'd never thought of that one...
Cheers,
Page 3 of 3 1 2 3
