Topics49,846
Posts837,383
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
Thats the way I have to do my mohair hood (it shrank slightly after reproofing). Usually with a pair of pliers to help fasten the last few turnbuckles. The correct way is to attach the rear, pull over erect hoodsticks then fasten lift-a-dots to windscreen. However, do be careful, you can crack the windscreen. I recommend some of John Taylor's over-centre hood swivels as Steve suggests. These allow the hoodsticks to sit a little lower while fastening the hood, then can be swung around to tension the hood. Can't be fitted to cars with bench seats (like my '76) though.
Cheers,
Posts: 6 |
Further to my question at 10:48, Has ayone any experience of the "Hood Frame "Swivel Pivots"" advertised on the website Morganhoods.com??
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
Go for it. As Graham says. We use them all the time, without them it is hard work. http://www.morganhoods.com/id70.html
Posts: 6 |
Thanks Graham and A11OGE I shall order them immediately!
No problem
Posts: 552 |
Assuming you have a the original hood design. It is like erecting a rig tent 1. Erect the hood bars 2. Clip the hood to the windscreen first. 3. Then attach to the rear. If this is impossible/hard, then it maybe because the hood is very tight against the hood bars. If this is the case I suggest you invest in a pair of Hood Swivels as advertised in Miscellany. make sure you fasten the centre lift the dot first on the windscreen - reduces the chance of breaking windscreen. if the hood hasnt been used for a while it can be tight. try taking it indoors to warm up for a bit!
Posts: 6 |
Managed to fit the hood last night without even having to take it indoors. A case of perseverance and not being a whimp. (Iv'e been driving citroens too long and have no strength left) BTW its much more fun to drive than I was led to believe. At least my wife will now also accompany me when it rains now!
Posts: 135 |
If this is the case I suggest you invest in a pair of Hood Swivels as advertised in Miscellany. One thing I've noticed - the Swivels cause bruising to the bum when we aged struggle to get out the car!
 Chris, I'd never thought of that one... Cheers,
