6 members (Strathaven, AlyMatt, DaveW, TeddyAds, High Hamster, +8Rich), 261 guests, and 83 robots.
+8Rich 80
DaveW 51
Topics49,866
Posts837,595
Page 8 of 9 1 2 3 4 5 6 7 8 9
I am on my second PCB and even that has part failed.
It would be great if someone could build better ones or offer a repair service.
Vibration could be a big factor. The first time I inspected the control box there was a rattling. The pcb was loose inside. I gently checked it , including light pressing of the chip (looked like eprom) before hot melt gluing it back. It worked for a while but more vibrations could well have caused the poor joints I eventually found, to fail. The box was screwed to the ash frame behind the dash. Maybe I should have put some vibration damping in ...rubber/neoprene. No problems since though.
Originally Posted By Deejay
No. Bulbs are resistive load rather than inductive loads.
He did say LED as opposed to filament.
Ok Bob, perhaps I missed his point by focussing on the function of a flyback diode.
No offence meant. I agree with what you say.
Best Regards
Lang may yer lum reek
I think the plethora of diodes is really all about quenching any high rise transients reaching and damaging the ECU it's what my Morgan/Classics Guru tells me.
Having worked extensively with Fairchild early 3.6volt rail and subsequently TTL came along with a 5volt rail and suppression was king I am in concord with his logic.
Christmas came early as I heard from BHM they have at last received a replacement PCB for my 4/4 from the Factory. I've been waiting since August
Seems this time my letter to the MD only sent last week resulted in a positive outcome!
Great news but don’t celebrate too early. You haven’t got the bill yet! I have heard of horror stories of £550+....
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
No bill it's under warranty!
But it would be £550 plus installation. I know from bitter experience.
Thank goodness it’s a warranty job.
However, your experience begs the question as to how a letter to the MD suddenly produces the goods? Unless he’s knocking them up in his garden shed of an evening, it would appear that the item was readily available in some way at the factory. I have had experiences of ordering a part from a main dealer only to be told it’s out of stock and unless I do chase ups, the order seems to disappear into the ether! Who should take the blame? Factory, for not having spares in the first place or dealer, for not having a robust follow up system.
Doug
1958 Triton 650
Well after having the PCB replaced after waiting the best part four months for the Factory to supply one it failed again. Fortunately BHM had one in stock so I'm now on to my third! My warranty expires next month!!
