0 members (),
383
68
Topics49,870
Posts837,668
Posts: 2,583 |
I took advantage of the warm weather today to grease the kingpins, only to find that the offside one was hidden behind the damper and I had to loosen it to enable the grease gun to clamp onto it. I`ve not had this problem before so I wonder if the nipple was changed at the last service for some reason. I`ll see about changing it for a differently angled one at the Resto Show.The nearside one was done in a couple of minutes. Also cleaned the inside of the wheels with WD40 whilst the wheels were off the ground. Then I took Megan out for a blast to check everything was OK and had a great top-down run for 30+ miles around the lanes of South Derbyshire. Days like today make me realise what a great privilege it is to have the ability to climb into a Morgan on a whim and just take off into the countryside. I got behind 4 hooded youths in a Peugeot with baked bean can exhaust and at a road works traffic light they all turned round and waved at me giving the thumbs up and smiling like toddlers - There`s hope for us yet!
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
I have always had this problem with the off side nipple whereas the nearside is fine. I wonder why they should be so different? 110 mile run out today in beautiful sunshine to see the progress on the SS100.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
I loosen the nipple off with a spanner to get access
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
Try a different grease gun head or adjust your existing one. I bought a cheap new one with flex hose and have had no trouble latching on since 😆
Posts: 1,118 |
Snap! Must be the weather for it! But my nipples behaved themselves!
RogT Old Git Racer ex 4/4 sand 2013 +4 GDI Royal Ivory 2015 Ford Fiesta ST2
Posts: 541 Likes: 7
Posts: 541 Likes: 7 |
You need to get the angle of the grease gun and the nipple to match so that the nipple can get into the grease gun head.
This is different on each side on my plus 4 and I have to turn the wheel a bit further out to do the offside.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
My offside nipple is also blocked off by the damper so turning the wheel slightly is the way to give clearance.
Posts: 192 Likes: 3
Posts: 192 Likes: 3 |
Also went for a spin today and come back and got the grease gun and my nipples behaved as well and then fitted Dave's mohair gaiters.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Posts: 308 |
I bought a nipple gripper 🤪. Works really well.
John 1936 Austin Seven Ulster Replica
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
I'm struggling with the nipples on my prop shaft... any tips on that? It seems to partially latch but when I pump the gun the nozzle just jumps off.
