10 members (mise303, B3MOG, JMcL, Soleng, Sir Percival, Jensen1960, High Hamster, Nick B, Bishmog, Rog G),
334
Topics48,348
Posts813,084
Members9,212
Posts: 31 |
Hi I am getting close to finishing my restoration of a 1969 Morgan 4/4 it is fitted with the Ford crossflow 1600gt ( competition) engine . Today’s issue is where does the throttle return spring on the carb fit ? Is there a bracket that should be fitted to the rocker cover ? Any ideas or photos much appreciated.
Posts: 1,613 Likes: 22
Posts: 1,613 Likes: 22 |
This is how mine is on 1971 4/4, an L shaped bracket from one of the manifold studs
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
If you are making your own bracket then why not make a setup with 2 springs? A bit of insurance for one breaking. It happened to me once. Managed the short trip home and afterthat kept a spare spring in the car as couldn’t be bothered fitting two.
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
Two are compulsory for competition driving.
Posts: 31 |
Thanks for the picture. On my car (earlier crossflow engine the spring is right up against the rocker cover. I have managed to fit a smaller bracket though the inlet manifold attached to one of the fixing bolts. My carb has a torsion spring on the throttle spindle plus the tension spring I have now fitted so effectively it has the two return spring required.
