Topics48,343
Posts813,023
Posts: 24 Likes: 1
Posts: 24 Likes: 1 |
Hello. I have recently completely rebuilt the side screens from my 1971 4/4 4seater; this was fairly straightforward with some learning experiences along the way. However, all nearly done now, and my question to the forum members concerns what adhesive to use on the rubber seal mitred corners surrounding the aluminium frame.
I have tried Super Glue, but it fails as soon as it is flexed; probably because the rubber has had a mould release agent added. The original factory seals came pre-cut and glued; with the glue used having a transparent look to it. Clearly vulcanising would be the best, but difficult to achieve at home.
Any suggestions welcomed - thanks, Mike.
Posts: 1,952 Likes: 41
Posts: 1,952 Likes: 41 |
You could try a local shoe repair shop for advice. They use flexible glues for rubber and leather.
Posts: 24 Likes: 1
Posts: 1,576 Likes: 103
Posts: 1,576 Likes: 103 |
An ordinary solvent based contact adhesive such as Alpha Thixofix should do it.
(Alpha took over making Thixofix when Dunlop stopped making it.)
Arwyn
Posts: 24 Likes: 1
Thanks Arwyn; I will try it. Mike Pullen
Posts: 1,148 Likes: 18
Posts: 1,148 Likes: 18 |
Mike I am very interested in the supplier of your rubber surround and the perspex can you advise please.
I have tried many rubber extrusion companies and cannot find the exact same as morgan used.
thanks Mike
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
photos would be god if you can upload please
Posts: 310 |
About 5 years ago I went to the factory that makes the sidescreens. at that time they were using Loctite 406 on the mitered corners
--------------------------- Mike Smith
2007 +4
Posts: 6,827 Likes: 59
Posts: 6,827 Likes: 59 |
Text is pretty good, too.
