7 members (Simon, CLPlusFour, TalkMorgan, Themorganeer, MJF, Jon G4LJW, Grumpy2), 307 guests, and 29 robots.
John V6 69
DaveW 68
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,026
RedThree
MikeJP Offline OP
Hello. I have recently completely rebuilt the side screens from my 1971 4/4 4seater; this was fairly straightforward with some learning experiences along the way. However, all nearly done now, and my question to the forum members concerns what adhesive to use on the rubber seal mitred corners surrounding the aluminium frame.
I have tried Super Glue, but it fails as soon as it is flexed; probably because the rubber has had a mould release agent added. The original factory seals came pre-cut and glued; with the glue used having a transparent look to it. Clearly vulcanising would be the best, but difficult to achieve at home.
Any suggestions welcomed - thanks, Mike.
You could try a local shoe repair shop for advice. They use flexible glues for rubber and leather.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
MikeJP Offline OP
A good idea - thanks.
An ordinary solvent based contact adhesive such as Alpha Thixofix should do it.
(Alpha took over making Thixofix when Dunlop stopped making it.)
Arwyn
MikeJP Offline OP
Thanks Arwyn; I will try it.
Mike Pullen
Mike I am very interested in the supplier of your rubber surround and the perspex can you advise please.
I have tried many rubber extrusion companies and cannot find the exact same as morgan used.
thanks Mike
Triumph Herald 1969 13/60
Morris 1970
photos would be god if you can upload please
Morris 1970
About 5 years ago I went to the factory that makes the sidescreens. at that time they were using Loctite 406 on the mitered corners
Mike Smith
2007 +4
Text is pretty good, too.
Best Regards
Lang may yer lum reek
