2 members (TBM, Ian Wegg), 249 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 7 of 8 1 2 3 4 5 6 7 8
Ricardo #602221 04/11/19 02:05 PM
Is there still an issue with the alignment holes in the steering rack?
Ricardo #602351 05/11/19 04:34 PM
Ricardo Offline OP
Blockley tyres fitted today, hmm, will I notice any difference from the Avons, time and cornering will tell ......
Ricardo #602376 05/11/19 06:23 PM
Try 28 psi, they will under steer for Britain in the wet but much better feel in the dry especially when warmed up.
I have a Michelin Cross Climate on the back and it shows just how crap the fronts are in the wet, but at least it is safer to drive on the road knowing the back end is planted.
Ricardo #602377 05/11/19 06:25 PM
How do you keep it soooooo clean when the weather and roads are filthy?
Ricardo #602381 05/11/19 07:32 PM
Did they loosen the fender to remove the wheel?
Do you think the Blockleys handle about the same as the Excelsior Comp H? Very si=milar tread pattern.
Ricardo #602399 05/11/19 11:46 PM
I don't think there is a big difference between the Blockley and Excelsior tyres, although they are both better than the Avon. It isn't until you move to something like the Michelin Commander II or Pirelli Night Dragons that you get an appreciable improvement in performance but that is at the expense of a reduced tyre life, less than half the mileage of the Blockley I would say. The big improvement I noticed with the Michelin tyres was the braking with no lock up, unless you really pushed hard on the pedal. They also fit under the mudguards better, you don't have to remove (or loosen) them to take the wheel off.
Ricardo #602404 06/11/19 12:52 AM
Definitely like the look of the pipes. I like how they made and bent the header pipes. Do you have cats? How loud is it?
I have the Morgan stage 1 exhaust and was thinking of letting the cats out of the pipes this winter to let things run a bit cooler.
2017 M3W Sport Green
2Sharp #602406 06/11/19 01:26 AM
Me too.
planenut #602407 06/11/19 01:29 AM
Thanks for the thyre info 👍
planenut #602419 06/11/19 07:53 AM
O
O
Hi Planenut
What width did you go for?
