1 members (david nathan),
463
32
SORN
New
Topics48,372
Posts813,497
Members9,215
Posts: 28 |
MOT due Monday and the fog light switch is illuminated but when depressed does not stay in and no rear fog light on . Is there easy fix for limited electrical knowledge! I have a blank switch next to it that stays in when depressed ..is this a simple swop over option or any other ideas—- the stress to solve by Monday Any help appreciated Mark
Never seen in non green
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
I don’t know which year your plus 4 is but my fog light switch is not latching (doesn’t stay in). It is a momentary switch that latches a relay on the circuit board behind. The headlights have to be on for the relay to latch and the switch to work.
Roger 2011 Plus 4
Posts: 28 |
Have realised fog switch is on with ignition and not supposed to stay in when depressed but no fog lamp showing at rear and the bulb is good and fuses too
Posts: 28 |
Roger - thanks I have 2012 plus 4 and confirm the latch ?? is not leering rear fog light come on
Have you tried the fuse? Number 5 I think under the dash passenger side, 7.5A.
Roger 2011 Plus 4
Posts: 28 |
Yes fuse fine and rear fog bulb and wires into light ok
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
The switch has a locking plate behind the pcb board on my 2006 car. If loose that might be the cause . It twists from memory.
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
I'm only asking the question in a different way but you have got the headlights switched on?
I did make that mistake myself.
Bob
Posts: 28 |
Yes head lights on Done both main beam as well
Have you got a Multimeter? If not get one, they're indispensable for tracking wiring faults.
If you have, take the bulb out and see if you are getting power to the lamp holder. If you are then even though it looks ok it's probably the bulb.
If not, work backwards towards the switch until you find power. That will locate the break in the circuit.
On my car you can tease the switch out and test the switch connections but not sure on your model.
How is the lamp earthed? Check it.
Bob
