2 members (Socalm3w, RichardV6), 363 guests, and 64 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Page 19 of 30 1 2 17 18 19 20 21 29 30
jrt Offline
Originally Posted by ChrisConvertible
Originally Posted by jrt
Having said that, most of the time I never use it - fuel consumption over the past year has been about 2 litres (in 9000 miles) BUT it is the get out of jail card when the battery is depleted and with that you're quite able to run the battery to its last few miles of range without worry of becoming stranded.
Doesn't fuel go off? It certainly does in my lawn mower if I don't use it for a couple of months. I would think you needed to use a tank every couple of months at least just to make sure the petrol is not too old.
It uses a completely sealed tank so presumably no evaporation = no change to the fuel. There is a venting / purging process that is initiated before you can open the filler cap.
Hamwich #617120 13/02/20 05:50 PM
Originally Posted by Hamwich
Originally Posted by craig123
and where do they go at the end of life .
End of life EV batteries don't get chucked away. They are re-purposed into storage arrays for virtual power plants/demand response systems for renewable generation sources. There is enormous demand for these, and the fact that vehicle batteries are generally lasting much longer than the original estimates predicted mean that the value is really quite high. That's what these installations are full of:
Just curious - where do they go after they have insufficient capacity for such use?
BTW I'm with you on the i3 Rex. BMW apparently dropped it as customers had problems with the ICE plant - mainly due to lack of use. Have a feeling I read that here somewhere...
I don't know, the Burton plant (which is the only one I know anything about) is still running with the original batteries. There's no UK recycling plant yet so I would think we'd have to get them recycled in a European plant until one is built.
Hi Graham
I don't know where this battery farm is located. We have one a few miles from where i live. It has a capacity of 40 Mw. Together with a bunch of local "engineering" types we visited. We were told that the deal on the batteries from the supplier was "for life" ie whenever a battery fails the supplier provides a replacement FOC. Nothing was said about SH batteries, but the "for life" suggests they might be SH because there will be a continuous supply from EV's. ....Very interesting i would say?
Ken A.
Plus 4 2009 Centenary Metallic Red
Plus 8 1994 Dark Green (prev)
Honda CB100 The Big One
meabh #617144 13/02/20 08:31 PM
Online NoMood
Shame we can't use Nickel Iron (NiFe) batteries developed by Thomas Edison 120 years ago and ironically used in very early US electric cars. Non polluting, typical life is a minimum of forty years with some known to be still performing after over a hundred as in this pre WW1 Detroit Electric. Could be a weight issue of course innocent
Click for more info.
meabh #617154 13/02/20 10:01 PM
Ray Offline
There has to be an end point at some time. Can't duck the issue forever. It sounds a bit head in sand to me.
Ken A #617155 13/02/20 10:08 PM
Thanks Ken.
I'd have enjoyed a visit to such a place.
Eventually, someone in the industry will advise where the expired batteries go...
RichardV6 #617207 14/02/20 11:08 AM
They are used a lot in the rail industry for backup if the power fails. Mostly level crossings.
Best Regards
Lang may yer lum reek
Hamwich #617209 14/02/20 11:10 AM
I have a fair few hemp shirts
Do you smoke 'em or are you just doing penance?
Best Regards
rofl
Actually they are really soft, almost like a fine flannel.
