3 members (Rex_tulips, mph, JohnMat), 310 guests, and 41 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,345
Members9,215
#619149 26/02/20 05:18 PM
PaulyG Offline OP
Pulled into a gas station the other day. A guy walking by said "There's something leaking under your car". I said of course there is...it's English!
Sorry.
What I have is a leak in the radiator, just under the lip near the top. Since I do air conditioning repairs I've been brazing pipes for years, but nothing this thin. Is this something I should attempt, or should I leave it to the experts?
It's a 73 4/4
Thanks
1973 4/4 "Henry A"
1953 +4 Flat Rad "Pug"
1984 Citoen 2CV Special "BeBe"
https://morgan34.org/
PaulyG #619155 26/02/20 05:40 PM
Solder can work well though I have used two pack epoxy repair methods with success also under the brand name Araldite Rapid in the UK
Good luck in your choices. thumbs
PaulyG #619160 26/02/20 05:59 PM
PaulyG Offline OP
A good silver solder might be a better option than brazing. Less heat needed to get it flowing. I think the prep might be the hardest part.
1973 4/4 "Henry A"
PaulyG #619161 26/02/20 06:04 PM
Get hold of some Coraline Flux if you can it's half the job done provided you have cleaned the surfaces well it's the key to successful soldering together with an adequate 150 Watt Iron..
2009 4/4 Henrietta
1993 Connaught Green +8 prev
PaulyG #619162 26/02/20 06:09 PM
Dare I suggest K seal ???
Regards, John.
PaulyG #619165 26/02/20 06:28 PM
PaulyG Offline OP
Not a fan of epoxys and sealers. I have more faith in solder or braze. Unless you know something I don't.
I want to remove the radiator to effect the repair. This way I can be sure I've got all the holes. Any suggestions and tricks to getting it out?
1973 4/4 "Henry A"
PaulyG #619167 26/02/20 06:44 PM
TBM Offline
I've got a 72 4/4. To remove, unbolt the three rubber bobbins (two at bottom and one at top). The top mount cross bar is easy to remove - screw in the two inside nuts, and then remove the two outside nuts and the bar comes out completely. Easy to swing the radiator out through the engine bay. Pretty sure you can slide it out with the bonnet in place, but much easier without it.
Picture shows top mount bobbin and top crossbar. My rad is about 15mm further forward due to electric fan.
PaulyG #619170 26/02/20 06:46 PM
PaulyG Offline OP
I was hoping it was that simple. Thanks.
Is the crossbar just there for the radiator, or is it adding front stiffness? How important is it that it is adjusted back to the same place it started?
1973 4/4 "Henry A"
PaulyG #619173 26/02/20 06:55 PM
I’ve had lots of success soft soldiering radiators in the past. I’ve also silver soldered and brazed them.
Radiator repairers I know always soft solder.
I’m sure you already know totally dry and spotlessly clean.
PaulyG #619207 27/02/20 02:02 AM
Luddite, don’t use Araldite rapid but the original ‘24 hrs to cure’ type, far far better.A friend and I fitted a Fish carb to a Beetle years ago, couldn’t get a suitable manifold for it so we Araldited the carb to the existing manifold, worked perfectly!
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
