9 members (davewhite, Uerikonplus8, Paul F, How, Black Adder, PeteMalvern, RichardV6, Dada, Hamwich),
349
Topics48,346
Posts813,060
Posts: 767 Likes: 45
Posts: 767 Likes: 45 |
Pulled into a gas station the other day. A guy walking by said "There's something leaking under your car". I said of course there is...it's English!
Sorry.
What I have is a leak in the radiator, just under the lip near the top. Since I do air conditioning repairs I've been brazing pipes for years, but nothing this thin. Is this something I should attempt, or should I leave it to the experts?
It's a 73 4/4
Thanks
Posts: 4,607 Likes: 193
Posts: 4,607 Likes: 193 |
Solder can work well though I have used two pack epoxy repair methods with success also under the brand name Araldite Rapid in the UK Good luck in your choices.
A good silver solder might be a better option than brazing. Less heat needed to get it flowing. I think the prep might be the hardest part.
Posts: 35,777 Likes: 468
Posts: 35,777 Likes: 468 |
Get hold of some Coraline Flux if you can it's half the job done provided you have cleaned the surfaces well it's the key to successful soldering together with an adequate 150 Watt Iron..
Posts: 121 |
Dare I suggest K seal ??? Regards, John.
Not a fan of epoxys and sealers. I have more faith in solder or braze. Unless you know something I don't.
I want to remove the radiator to effect the repair. This way I can be sure I've got all the holes. Any suggestions and tricks to getting it out?
Posts: 6,057 Likes: 160
Posts: 6,057 Likes: 160 |
I've got a 72 4/4. To remove, unbolt the three rubber bobbins (two at bottom and one at top). The top mount cross bar is easy to remove - screw in the two inside nuts, and then remove the two outside nuts and the bar comes out completely. Easy to swing the radiator out through the engine bay. Pretty sure you can slide it out with the bonnet in place, but much easier without it. Picture shows top mount bobbin and top crossbar. My rad is about 15mm further forward due to electric fan. ![[Linked Image]](https://tm-img.com/images/2019/11/30/Fan.jpg)
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
I was hoping it was that simple. Thanks.
Is the crossbar just there for the radiator, or is it adding front stiffness? How important is it that it is adjusted back to the same place it started?
Posts: 1,384 Likes: 56
Posts: 1,384 Likes: 56 |
I’ve had lots of success soft soldiering radiators in the past. I’ve also silver soldered and brazed them.
Radiator repairers I know always soft solder.
I’m sure you already know totally dry and spotlessly clean.
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
Luddite, don’t use Araldite rapid but the original ‘24 hrs to cure’ type, far far better.A friend and I fitted a Fish carb to a Beetle years ago, couldn’t get a suitable manifold for it so we Araldited the carb to the existing manifold, worked perfectly!
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
