1 members (Soleng),
330
52
Topics48,347
Posts813,062
Posts: 6,057 Likes: 160
Posts: 6,057 Likes: 160 |
I've heard a lot of good things about JB Weld - there's an amusing You tube video where a bloke cuts a chunk out of a cylinder head with a grinder, fixes it with JB Weld and gets the engine running!
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
I was hoping it was that simple. Thanks.
Is the crossbar just there for the radiator, or is it adding front stiffness? How important is it that it is adjusted back to the same place it started? I think it's both. It appears to stop the wing tops splaying. I've removed mine a couple of times and just refitted it with the wing position as the guide. I imagine the main flex is during use. It might be worth measuring the distance first to make sure it goes back exactly.
Posts: 2,041 Likes: 71
Posts: 2,041 Likes: 71 |
Is the crossbar just there for the radiator, or is it adding front stiffness? How important is it that it is adjusted back to the same place it started? I think it's both. It appears to stop the wing tops splaying. I've removed mine a couple of times and just refitted it with the wing position as the guide. I imagine the main flex is during use. It might be worth measuring the distance first to make sure it goes back exactly. Before I remove the crossbar I mark the position of the nuts with a dab of white paint, I can then position it exactly as it came off on replacement.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Posts: 6,827 Likes: 59
Posts: 6,827 Likes: 59 |
I've heard a lot of good things about JB Weld - there's an amusing You tube video where a bloke cuts a chunk out of a cylinder head with a grinder, fixes it with JB Weld and gets the engine running! https://www.youtube.com/watch?v=aVLoJe3JbFI
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
+1 for JB Weld but never used it on a radiator, or for cylinder head repairs
Bob
Posts: 767 Likes: 45
Posts: 767 Likes: 45 |
