5 members (bmgermany, RichardV6, Rex_tulips, mph, JohnMat), 330 guests, and 41 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,345
Members9,215
PaulyG #619220 27/02/20 07:23 AM
TBM Offline
I've heard a lot of good things about JB Weld - there's an amusing You tube video where a bloke cuts a chunk out of a cylinder head with a grinder, fixes it with JB Weld and gets the engine running!
PaulyG #619221 27/02/20 07:28 AM
TBM Offline
Originally Posted by PaulyG
I was hoping it was that simple. Thanks.
Is the crossbar just there for the radiator, or is it adding front stiffness? How important is it that it is adjusted back to the same place it started?
I think it's both. It appears to stop the wing tops splaying. I've removed mine a couple of times and just refitted it with the wing position as the guide. I imagine the main flex is during use. It might be worth measuring the distance first to make sure it goes back exactly.
TBM #619362 27/02/20 05:45 PM
Before I remove the crossbar I mark the position of the nuts with a dab of white paint, I can then position it exactly as it came off on replacement.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
TBM #619375 27/02/20 06:39 PM
https://www.youtube.com/watch?v=aVLoJe3JbFI
Best Regards
Lang may yer lum reek
PaulyG #619380 27/02/20 07:19 PM
+1 for JB Weld but never used it on a radiator, or for cylinder head repairs
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
PaulyG #625379 24/03/20 01:33 AM
PaulyG Offline OP
OK, so here is the follow up. I found that the radiator had been repaired with epoxy in the past, so my idea of soldering the leak might be dead. I sealed the ports and put 5 psi on it, placing it in a tub of water. The leak was coming from behind the top mounting bracket. I decided the only course of action was to inject some epoxy in from both sides. Worked perfectly. The radiator is back in the car and as is well. I found that removing the grill made the job much easier.[Linked Image][Linked Image][Linked Image]
1973 4/4 "Henry A"
1953 +4 Flat Rad "Pug"
1984 Citoen 2CV Special "BeBe"
https://morgan34.org/
