2 members (Chris Cosher, Ian Wegg), 171 guests, and 117 robots.
+8Rich 75
Topics49,869
Posts837,654
Moggo
My 1994 plus 4 has the Perspex wind deflectors fitted onto the windscreen and I’m not sure they look right. I know they’ll come off easy enough but what size are the screws that will need replacing? Not of my metric screws will fit so I think they’re either UNF or BA. Anyone know the size and where I’d get replacements please?
Tony
1994 Connaught Green Plus 4
I got mine from Ebay and you are right they aren’t metric
I’ll look back and see if I made a note of what they are
One way you can do it is to measure the precise diameter in mm’s using a gauge and then consult the UNF and BA charts to identify the correct size machine screw
Just remember 25.4mm to an inch when doing your calcs
Remember to watch the length ! Don’t crack the screen!
Havent measured the screw - but the length on second try.
You can get them at Melvyn Rutters.
https://mogparts.net/product/windscreen-screw-set-stainless-chrome-plated
1973 2CV AK400 Ralley
1985 plus 4 four seater
1992 Peraves ecomobil
bicycles (pedersen to recumbent)
The note I have made from another forum is that they are 10-32
However I did visit the company that makes the screens and they said the screws are 1/4 whitworth. I have a spare screen and will check
Mike Smith
2007 +4
I have checked my spare screen (9 stud) and a 2 BA screw fits, and a 10-32 will also fit, the tpi is very close. I expect the original fit is 2BA and someone in the USA has found that a 10-32 does the job
Mike Smith
2007 +4
Thanks everyone. Found a place where they’re literally pennies each so ordered a set of BA and also the 10-32 just in case. Thanks again
Tony
I checked a couple of windscreen frames I have stored away, which includes a factory 'easy up', and they have the same thread.
Mike Smith
2007 +4
Just to close this out, the correct size is 2BA. The 10-32 would fit (by forcing it) but I think it would ultimately knacker the thread. Or, at least this was the case on my plus 4
Tony
