6 members (Scrambledsignals, BobtheTrain, Brian Dearle, Lordofthewings, JD44, verysideways), 261 guests, and 42 robots.
John V6 68
+8Rich 66
DaveW 64
9,208 Registered Users
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,346
Posts813,060
Captain Morgan, IRWIN
#645861 21/06/20 03:42 PM
The horn on my 2009 4/4 has failed, suspect it's the relay. How do I get to it ?
Richard J
Richard J #645872 21/06/20 05:01 PM
Replace the horn they fail, MMC didn't usually it a relay. Test it with a multi meter for resistance to be sure.
If you car has one horn as MMC designed t you can add a second as the wiring should be there
If you buy new horns they usually come with a relay.
I fitted a nautilus horn & used the second horn supply for a relay.
2025 MG ZS EV aka Trigger
Richard J #645873 21/06/20 05:01 PM
By the way welcome.
Richard J #645905 21/06/20 09:43 PM
You could also check the power feed to the horn Richard if you have a multimeter. With ignition switched on measure the light green/white cable that connects to the horn (or the spare cable of same colour for second horn) with respect to ground/chassis. There should be +12 volts on this cable all the time as the horn switch is on the ground side. If no 12 volts, check fuse 9 (10 amp).
If as John suggests the horn itself has failed then good opportunity to upgrade to matching high/low tone pair (given extra wiring already present). They are as cheap as chips on eBay.
Richard J #645906 21/06/20 09:53 PM
Richard J
I had problems with the factory horn, so I fitted these twin Fiamm horns, only about £16.00
Craig Jezz
RichardV6 #645990 22/06/20 12:08 PM
Thanks for the info, will check again
John V6 #645991 22/06/20 12:09 PM
Craig Jezz #646139 22/06/20 08:56 PM
Richard J
I would suggest mounting the horns with the opening facing down to prevent water from entering ..
I used this horns also on my CX500 w. sidecar. One day I had to use them in a dangerous situation!
They did not work! At the next break I removed all the snow out of the horns
banghead
bmgermany #646150 22/06/20 09:37 PM
Richard J
banghead
“That’s a great idea. I,ve Also been wondering how I would stop snow going down the back of my neck. I suppose I could sit upside down. But then I’d get salt up my arse.” Probably better to leave it in the garage
Craig Jezz
John V6 #646157 22/06/20 10:00 PM
Have found the problem, fuse had gone plus bad connections at steering wheel, poor contact between alloy boss and stainless.steel horn push.
Thanks to all for feed back
