2 members (Soleng, Black Adder),
314
52
Topics48,347
Posts813,062
Posts: 7 |
The horn on my 2009 4/4 has failed, suspect it's the relay. How do I get to it ?
Richard J
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Replace the horn they fail, MMC didn't usually it a relay. Test it with a multi meter for resistance to be sure.
If you car has one horn as MMC designed t you can add a second as the wiring should be there If you buy new horns they usually come with a relay.
I fitted a nautilus horn & used the second horn supply for a relay.
Posts: 7,924 Likes: 217
Posts: 7,924 Likes: 217 |
You could also check the power feed to the horn Richard if you have a multimeter. With ignition switched on measure the light green/white cable that connects to the horn (or the spare cable of same colour for second horn) with respect to ground/chassis. There should be +12 volts on this cable all the time as the horn switch is on the ground side. If no 12 volts, check fuse 9 (10 amp).
If as John suggests the horn itself has failed then good opportunity to upgrade to matching high/low tone pair (given extra wiring already present). They are as cheap as chips on eBay.
Posts: 2,222 Likes: 20
Posts: 2,222 Likes: 20 |
Richard J
I had problems with the factory horn, so I fitted these twin Fiamm horns, only about £16.00 ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/3E569A60-4B9A-4586-A02F-1AF555EA47E6.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/B9CFBB60-A0A4-49EE-A830-E79101343141.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/68E75B66-5FBA-47F8-81E1-019A553015D9.jpg)
Craig Jezz
Posts: 7 |
Thanks for the info, will check again Richard
Posts: 7 |
Posts: 2,063 Likes: 57
Posts: 2,063 Likes: 57 |
Richard J
I had problems with the factory horn, so I fitted these twin Fiamm horns, only about £16.00 ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/3E569A60-4B9A-4586-A02F-1AF555EA47E6.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/B9CFBB60-A0A4-49EE-A830-E79101343141.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/68E75B66-5FBA-47F8-81E1-019A553015D9.jpg) I would suggest mounting the horns with the opening facing down to prevent water from entering .. I used this horns also on my CX500 w. sidecar. One day I had to use them in a dangerous situation! They did not work! At the next break I removed all the snow out of the horns
Richard J
I had problems with the factory horn, so I fitted these twin Fiamm horns, only about £16.00 ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/3E569A60-4B9A-4586-A02F-1AF555EA47E6.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/B9CFBB60-A0A4-49EE-A830-E79101343141.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/03/10/68E75B66-5FBA-47F8-81E1-019A553015D9.jpg) I would suggest mounting the horns with the opening facing down to prevent water from entering .. I used this horns also on my CX500 w. sidecar. One day I had to use them in a dangerous situation! They did not work! At the next break I removed all the snow out of the horns  “That’s a great idea. I,ve Also been wondering how I would stop snow going down the back of my neck. I suppose I could sit upside down. But then I’d get salt up my arse.” Probably better to leave it in the garage
Craig Jezz
Posts: 7 |
Have found the problem, fuse had gone plus bad connections at steering wheel, poor contact between alloy boss and stainless.steel horn push.
Thanks to all for feed back
