7 members (Ncik P, MartinB60, +8Rich, Luddite, Nick55, DaveW, Mats),
214
47
Topics49,863
Posts837,566
Posts: 22 |
Dear all, Does anybody know where the eletrical motors of an Aero S1 side windows come from? It is a Bosch part.
The last time I had a huge difficulty to get from the factory an electric steering pump, and in fact it was a part for a Mini(BMW)! Thank you for your help
Or is there a factory kit (cables and motor) to repair it?
Chris Aero S1 silver
Posts: 536 |
Hello Chris
Replaced rt hand motor on my S1 a couple of years ago. Bought the replacement part from BHM (eg Morgan part) for about 170€. Not that cheap but at least when it comes to fitting probably the easiest window winder mechanism i have ever had to access (no nasty breaking clips!)
If you do the job have a look at the top pulley, on mine it was not turning due to a poor spot weld on the frame, and hence the cable frayed.
Cheers
Philip
1985 Plus 8 four seater Malone F1000 - track car
Posts: 378 |
Hi Chris Mine is currently being replaced as it burnt out. I will try and see if the garage can supply the old one in the box it came in-if you get my drift! This is the third motor now its gone through !!!
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 22 |
Thank you Philippo for your answer Do you remember if BRM provide a complete kit (with cables) or only the motor?
Posts: 536 |
Chris
It was motor and cables. Just as well since in my case motor still worked and cable was damaged.
Cheers
Philip
Posts: 1,764 |
Tried tracking all this down in the past but got nowhere and had to get the factory kit. I think the motor itself is from a Fiesta.
Phil Egginton 1979 4/4 4 seater
