Morgan Aero 8
4 members (High Hamster, MATTMOG, RichardV6, nick w), 199 guests, and 58 robots.
+8Rich 76
Topics49,863
Posts837,550
Chrisa8 Offline OP
Dear all,
Does anybody know where the eletrical motors of an Aero S1 side windows come from? It is a Bosch part.
The last time I had a huge difficulty to get from the factory an electric steering pump, and in fact it was a part for a Mini(BMW)!
Thank you for your help
Or is there a factory kit (cables and motor) to repair it?
Chris
Aero S1 silver
Hello Chris
Replaced rt hand motor on my S1 a couple of years ago. Bought the replacement part from BHM (eg Morgan part) for about 170€. Not that cheap but at least when it comes to fitting probably the easiest window winder mechanism i have ever had to access (no nasty breaking clips!)
If you do the job have a look at the top pulley, on mine it was not turning due to a poor spot weld on the frame, and hence the cable frayed.
Cheers
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Hi Chris
Mine is currently being replaced as it burnt out. I will try and see if the garage can supply the old one in the box it came in-if you get my drift! This is the third motor now its gone through !!!
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Chrisa8 Offline OP
Thank you Philippo for your answer
Do you remember if BRM provide a complete kit (with cables) or only the motor?
Chris
Aero S1 silver
Chris
It was motor and cables. Just as well since in my case motor still worked and cable was damaged.
Cheers
Philip
Tried tracking all this down in the past but got nowhere and had to get the factory kit. I think the motor itself is from a Fiesta.
Phil Egginton
1979 4/4 4 seater
