2 members (MATTMOG, Mogdavid),
338
80
Topics49,849
Posts837,415
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
The plate is a damper blade which your car won't have. Guidance on greasing is here by year of build.You have bearings instead though I note the article still refers to a damper blade. Greasing
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
John, Many thanks I’ll have a good read and digest it.
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
Paul. Were they the originals or have you had hard chrome fitted? Originals. I fitted DaveW's gaiters to the lower springs as soon was I got the car home. It's the best I have done so far - the previous car never did as well.
Posts: 2,087 Likes: 70
Posts: 2,087 Likes: 70 |
Bringing things back down to earth...ANY grease is better than no grease!
Bringing things back down to earth...ANY grease is better than no grease! +1 And a rebound spring gaiter makes a huge difference - the grease on the exposed king pin attracts road dust and grit which accelerates wear in the lower bush. I remember Mike Duncan telling me once that he rarely changes the upper bush on cars as it wears so little compared to the lower one which gets all the crud.
Posts: 697 Likes: 7
I m taking the car to wolf performance so was going to get their gaiters fitted whilst it is being fixed
Posts: 57 |
A bit of advice needed, if you'd be so kind.
Having had enough of juggling with a lever style grease gun I thought one of these blighters might be easier to use for my remote kingpin nips.
Is the 6k PSI figure of any significance? I don't want to do any damage.
Thanks.
https://www.amazon.co.uk/CarBole-Lubricants-Anodized-Aluminum-Canister/dp/B0812QFC54/ref=sr_1_8?crid=K9128RM4L78K&dchild=1&keywords=pistol+grip+grease+gun&qid=1611953100&sprefix=pistol+grip+grease%2Cdiy%2C153&sr=8-8
Sorry, I thought it would be a link. Apparently, I don't get on well with technology.
Rich Maroon and Ivory (ish) Plus 4 2015
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
A lever style gun will have that capability more so than the trigger type, you’d need a grip like Mike Tyson to achieve it - it’ll be fine.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
It seems pretty expensive as well. I good lever gun works better. I do though have one of these for touring. Hilka grease gun
I also use a grease gun coupler. That makes it much easier. Coupler
