8 members (TBM, bmgermany, CooperMan, RichardV6, MOG42, SteveT, JoeSpeetjens, TeddyAds), 261 guests, and 57 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,350
Christoph
John V6 Offline OP
Being bored in lockdown I ordered an MMC start button for the Roadster. I have always wanted a car with a start button. Sad I know .
As the 3.7l cars have a jumper lead on the plug behind the dash it should simply be :-
1. Remove the under dash panel by undoing the screws.
2. Remove the plug on the dash
3. Remove the jumper plug and fit the switch
4. Reconnect
What could go wrong after all it is a Morgan.
Alas BHM had the wrong switches from MMC despite the right part number and as you can see the plugs are very different.
.The jumper on the dash roll & the wrong switch connector
The six pin connector under the dash.
Sarah at BHM was very helpful and a few days later the right switch arrived was fitted & works.
One word of caution the back of the switch can go on 2 ways.
Under the dash showing the PCB in the correct alignment
PCB facing up means the flashing green light on the switch before you start doesn't work. Naturally you will have noticed this feature before you put it all back together. If you do that wrong & refit the under dash panel you need to take it apart & get it right. Don't ask how I know.
The right switch
I also discovered the map light wiring which is free & is always powered up. I might later fit a USB socket if I can be prepared to unscrew the under dash panel again.
Green for start . The flashing light on the switch. I also managed to fit an MMC badge into one of the remaining switch blanking plates.
Formerly known as Aldermog
John,
there is nothing sad about wanting a "Start" button,... Tarka has one!
Simple things please simple minds, it is said. I must have a very simple mind!
John V6 Offline OP
Me too. I just love it.
That’s a cracking job there John
Gotta love a start button!!!
Nice one
Hope to see it in the flesh one day...
HB
Golf ehybrid thingy “Toadie”
Polestar 4 “Vger”
John V6 Offline OP
That would be nice I agree. Not long now if all goes well till we can have Mog related events.
Online NoMood
Good result John thumbs
Does the switch pull apart for fitting into dash hole and then click into place?
BTW for 2 x USB power I have a compact cigar lighter adaptor.
John V6 Offline OP
It splits in 3. The square bit below the pcb is held on by a plastic screw to the main body of the switch. Then there is a round threaded nut that unscrews to go behind the dash.
I also have the compact USB adaptor.
Back in the 60's the first thing we would do with our Minis was remove the floor start button and convert to the latest novelty, key start!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
My S11a Land Rover had a "start" button laugh2
John V6 Offline OP
My sisters mini had a start button & my first boss's 1970s Granada hada floor mounted screen wash button.
As I said I am reverting to my childhood.
