5 members (Robbie, MATTMOG, DavidR, JohnHarris, Bobajobbob), 494 guests, and 38 robots.
+8Rich 70
Adam12 69
John V6 53
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,508
Members9,215
Winglad
Say guys, I am putting in a new tire and trying to get the belt adjusted just right. Any advice based on these photos? I used same size tire as original.
Also, how tight to make the axel nut: it backed off a bit when it stopped to slip in cotter pin. Do I want to make it super f'ing tight (go to next cotter pin hole?).
end user
You want it super tight.
Your wheel and tire do not look centered to me, could be the angle the photo was taken, but it looks like it is pointed a bit to the left.
As a starting point I will lay a yardstick on the belt, inline with the edge the belt and run it back far enough to cross both edges of the tire. Adjust positioning until there is equal space between both sidewalls and the edge of the yardstick..
Tighten the axle bolts, rotate the tire and see how the belt tracks.
I took an old unused (aren't they all) treadmill l and reversed the wiring so it would run backwards. With the rear of the trike on jack stands and the transmission in neutral, I slide the edge of the treadmill under the rear tire so that the treadmill will run the tire. This allows me to adjust tire alignment as it runs in a safe manner.
Make sure the belt has no opportunity to touch the side wall. The belt is much stronger than the sidewall of the tire and will chew it up risking a sidewall blowout[Linked Image]
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
It also looks like there are bits of belt being left on the little half fender. I cut a notch in mine so it would not hit it.
May be part of his noise problem. I had to trim mine also
Lance
1981 Plus 8
2016 Three Wheeler
usually the saying is "tighten until it breaks and back off 1/4 turn" in this case,"f'in" is about right
I fittled and fittled with centering. Ran it multiple times whilst the rear wheel was raised. Like medicine, it is science, but then again it is an art
Rodger
2004 Plus 8 (wife's)
definitely more of an art than science
Lance
1981 Plus 8
2016 Three Wheeler
I agree with Lance in that your wheel alignment is ‘out’, and yes the nut should be tight, very tight...
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
FT every time.
200lbs/ft on the torque wrench then tighter until the "r" clip goes through the hole.
Never had any movement.
Okay, I will turn to next hole for cotter pin. I am worried about messing with the bearings if too tight. I think the belt is in position.
end user
they are not tapered bearings so you cannot over tighten like you might with tapers
Rodger
