7 members (sprinty, Image, BobtheTrain, AlyMatt, Calypso Red, MJF, JohnHarris),
343
91
Topics49,847
Posts837,389
Posts: 3,847 Likes: 400
Posts: 3,847 Likes: 400 |
I would have thought the most natural thing to do for those that have any concerns over E10 petrol (which will be readily available) would be to alternative fill ups between E10 and super unleaded. And if storing over winter make sure it's filled with super unleaded to reduce the potential water separation whilst in storage. I never unless going on a long journey allow my tank to go much below half full , so alternating petrol types will in theory give me something equivalent to combined E5 petrol (assuming super leaded has no E in it). The big unknown will be how long super unleaded will continue to be readily available and as I understand it the Government's intentions with regard to increasing beyond E10 to force petrol cars off the road.
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
I've now swapped to using StarTron Enzyme. For our top pick, we chose Star Tron's Enzyme Fuel Treatment. This additive has unique enzyme technology that is specially designed to work great for both your daily driver or a vehicle you keep stored for months at a time. It's used to stop ethanol fuel problems and prevent phase separation.
This fuel stabilizer additive eliminates and prevents ethanol fuel problems by breaking down excess water and sludge. The smaller particles are safely burned up when running your engine. The cleaner fuel system will allow your vehicle to operate more efficiently and give you better performance. The added efficiency can also lead to a considerable improvement in your overall gas mileage. This additive also guarantees two years of protection for your fuel system.
While this is the best fuel stabilizer for ethanol fuels, it isn't perfect for every job. Specifically, it's not applicable for diesel fuel (Star Tron offers a separate additive for diesel). The bottle design is also awkward, which can make it difficult to pour into your vehicle.
Is the Star Tron's Enzyme Fuel Treatment for leaded petrol engines?
Is the Star Tron's Enzyme Fuel Treatment for leaded petrol engines? No, it's not a lead replacement additive. You need something like valvemaster for that.
Posts: 132 |
So, I'm a little late to this party.
Is it ok to fill my 4/4 CVH engine with E10, or should I avoid it?
Is it ok to fill my 4/4 CVH engine with E10, or should I avoid it? Stick in some StarTron every so often and you should be ok
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
While this is the best fuel stabilizer for ethanol fuels, it isn't perfect for every job. Specifically, it's not applicable for diesel fuel (Star Tron offers a separate additive for diesel). The bottle design is also awkward, which can make it difficult to pour into your vehicle. I dont see this. Sure we use something similar to deal with the end result of minor amounts of water in diesel in the boat - to break down the sludge that forms at the water / fuel interface. However, this additive and any other for that matter, wont stop the 10% ethyl alcohol rotting the rubber pipes and seals which arent alcohol resistant. Not to mention plastic tanks as Ducati used and which distorted heavily in the USA.Or the pipes in my chain saw and strimmer.
Posts: 3,693 Likes: 130
Posts: 3,693 Likes: 130 |
Posts: 535 Likes: 1
Posts: 535 Likes: 1 |
Whilst I do understand the concept of the E-number in unleaded fuel as well as the RON and the benefits both have for an engine, combined with the additional additives that the fuel companies put in their higher-performance versions, I am lacking in similar knowledge about Diesel fuel. Therefore my comments and questions are as follows:
1. I always use the higher-performance version available. Until recently I was very much a Shell V-Power man and have recently switch completely to Esso Synergy Supreme +99 as Esso clearly state that in most of the UK there is zero Ethanol in this fuel. I even use this in my lawnmower as it lasts far longer in the tank which is very helpful over the winter.
2. I have therefore blindly used the equivalent higher-performance Diesel in my Range Rover, however I have no idea what the B-number is and as Diesel doesn't have a RON I am beginning to wonder if there is a similar benefit in paying the extra for the allegedly better fuel. Is anyone able to assist me in understanding a little more about the make up and differences between regular Diesel and, say V-Power Diesel so I can make a more informed choice?
Cheers, Paul
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
snip..................
2. I have therefore blindly used the equivalent higher-performance Diesel in my Range Rover, however I have no idea what the B-number is and as Diesel doesn't have a RON I am beginning to wonder if there is a similar benefit in paying the extra for the allegedly better fuel. Is anyone able to assist me in understanding a little more about the make up and differences between regular Diesel and, say V-Power Diesel so I can make a more informed choice? I only use Q8 Hi Perform (or Hi Q) Diesel in the Jaguar despite now costing over €2 a litre. My previous experience with the Alfa Romeo Crosswagon was that under acceleration with normal diesel there was an emmision of black fumes, presumably fine carbon particles (no particle filter back then), but with the Hi Perform Diesel the were no visible fumes. It is highly subjective but I also think that there is a slight increase in power and a lower consumption. Certainly it burns cleaner. In fact I am surprised that legislation does not require the use of the cleaner, premium diesel in passenger cars.
