7 members (John V6, Hamwich, Mike D, Ricardo, mph, DavidR, Richardllll),
367
Topics48,349
Posts813,091
Members9,212
Posts: 712 Likes: 8
Posts: 712 Likes: 8 |
Driving up the Grimselpass this week my wife suddenly lost all traction in her M3W. Shifting gears was possible. The revs went up normal But the car wouldn’t go forward. She stopped and we changed cars. To my surprise I could get the car moving like normal. Very strange. We couldn’t get a clue what happened. All looked normal again and we could drive home 100 kilometers without any problems. Today we went out for a short ride. After 30 kilometers suddenly the same happened again. We stopped. I went in her car and drove away like normal. But this time there was a noise from the back of the car. Suddenly same happened as above and lost all traction. Looking under the back I found out what was wrong. The Supermax sprocket gave up his duty. So need to get a new one. The only question remains how was it possible, after the first time this happened, to drive an other 130 kilometers without any problems? ![[Linked Image]](https://www.tm-img.com/images/2021/09/04/6FD3E1E7-B792-4940-93F7-6DDD73EE6FFA.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/09/04/D2ABDC54-FC06-4F2F-ABD2-57885F830777.jpg)
Posts: 358 |
92 Connaught Green Plus 4 Triumph Bonneville 865
Posts: 1,363 Likes: 11
Posts: 1,363 Likes: 11 |
Yup. Well, I'm not terribly surprised after my own fiasco with the rear sprocket. Don't bother with a SuperMax sprocket. Just get the newer steel stock sprocket and be done with it.
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
A similar thing happened with a Supermax sprocket at G&G in the Lakes a few weeks ago (photo below). The poly overlay disbonded and the grub screws sheared off or worked lose, not sure which happened first. The owner stopped and investigated this at the first occurrence and found the problem before any damage was done to the poly overlay. The car was recovered and the rear wheel removed. The overlay was then bonded back on with epoxy adhesive and new grub screws fitted. All refitted and the M3W returned to action the following day. Other Supermax sprockets have had the grub screws work lose, they need to be secured with Loctite. Bunny mentioned this was an issue with Supermax sprockets in April 2019. ![[Linked Image]](https://www.tm-img.com/images/2021/09/04/P1030537.jpg)
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
Posts: 488 |
Ian what's the bent twist drill and pipe all about?
You would have to ask Dab of Oppo about that as it is his car. Something to do with his fabricated rear mudguard I think, there are several variations.
Posts: 488 |
Think it’s called upcycling.
Posts: 1,673 Likes: 25
Posts: 1,673 Likes: 25 |
Ian what's the bent twist drill and pipe all about? Good use of an old blunt drill bit!
Andy
The Supermax sprocket gave up his duty. So need to get a new one. I believe that M3W Services have brand new Supermax sprockets in stock if you need to get hold of one quickly.
Andy
