Morgan Aero 8
2 members (Chris Cosher, JohnHarris), 291 guests, and 37 robots.
+8Rich 92
Posts837,277
#7177 29/08/07 06:35 PM
Is it me or do we all have trouble getting fuel in the tank. banghead
My Series 1 'clicks' off at anything but a trickle. ooo
Phil Egginton
1979 4/4 4 seater
SpeedMog #7178 29/08/07 06:40 PM
kin Offline
Mine does it, but only on certain pumps confused2
kin #7181 29/08/07 07:47 PM
NGUNS!!
NGUNS!!
I can brim it but have to hold it half out and then lack of concentration means petrol soaked shoes doh
BtG
Cheers
BtG
kin #7182 29/08/07 07:49 PM
I believe that problem stems for the fact the fuel cap (and pipe) is from a motorcycle. I could never get my tank to show full and if I pushed it past the point where it wanted to 'cut off' due to back pressure, the tank would start to spill fuel onto the boot.
Not a very good design, truth be told.
Simon #7220 30/08/07 06:04 AM
Anonymous
Unregistered
Anonymous
Unregistered
Would I be correct in thinking that Morgan use a Yamaha tank top for the Aero 8?
#7221 30/08/07 06:29 AM
Yes, and as Simon says it is not a very satisfactory solution to the problem. gloomy
Brian
2014 Morgan SP1 (Rocket Red)
Aeroman #7227 30/08/07 06:50 AM
Anonymous
Unregistered
Anonymous
Unregistered
Don't complain. If I told you how it is to fill the new 4-seaters up you would be VERY happy with your problems (grin). (Aeroman knows the story.)
Roderich
#7229 30/08/07 06:53 AM
You should publish a photo of the partial fix Roderich, as that pipe is a work of art! doh
Brian
#7232 30/08/07 07:02 AM
Roderich
Yes, it is terrible that you were forced to deal with this Roderich - just not acceptable.
If, as Aeroman has said, you've found a solution, it would be worth posting it in the Trad section as there may be others out there with the same issue.
Cheers
Simon
Simon #7234 30/08/07 07:05 AM
Mr Fezza
Mr Fezza
Usually gets a bit 'clicky' at BP stations. Always seems to be BP, and I guess they just force the petrol out faster or something.
One remedy I ahve found is to twist the pump handle nozzle round 180 degrees so the handgrip is furthest away from you standing at the rear - that seems to help speed up the flow you can use if not completely curing the issue.
Maxxed out!
