Topics49,839
Posts837,302
Posts: 1,764 |
Is it me or do we all have trouble getting fuel in the tank.  My Series 1 'clicks' off at anything but a trickle.
Phil Egginton 1979 4/4 4 seater
Posts: 2,321 |
Mine does it, but only on certain pumps
NGUNS!! Part of the Furniture
Posts: 4,564 |
I can brim it but have to hold it half out and then lack of concentration means petrol soaked shoes  BtG
Cheers
BtG
Posts: 7,929 Likes: 131
Posts: 7,929 Likes: 131 |
I believe that problem stems for the fact the fuel cap (and pipe) is from a motorcycle. I could never get my tank to show full and if I pushed it past the point where it wanted to 'cut off' due to back pressure, the tank would start to spill fuel onto the boot.
Not a very good design, truth be told.
Anonymous
Unregistered
Anonymous
Unregistered
I believe that problem stems for the fact the fuel cap (and pipe) is from a motorcycle. Would I be correct in thinking that Morgan use a Yamaha tank top for the Aero 8?
Posts: 7,363 |
Yes, and as Simon says it is not a very satisfactory solution to the problem.
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Anonymous
Unregistered
Anonymous
Unregistered
Don't complain. If I told you how it is to fill the new 4-seaters up you would be VERY happy with your problems (grin). (Aeroman knows the story.)
Roderich
Posts: 7,363 |
You should publish a photo of the partial fix Roderich, as that pipe is a work of art!
Brian
Roderich Yes, it is terrible that you were forced to deal with this Roderich - just not acceptable. If, as Aeroman has said, you've found a solution, it would be worth posting it in the Trad section as there may be others out there with the same issue. Cheers Simon
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
Usually gets a bit 'clicky' at BP stations. Always seems to be BP, and I guess they just force the petrol out faster or something.
One remedy I ahve found is to twist the pump handle nozzle round 180 degrees so the handgrip is furthest away from you standing at the rear - that seems to help speed up the flow you can use if not completely curing the issue.
-------------- Maxxed out!
