0 members (),
145
67
Topics49,861
Posts837,542
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
One day in, and to make M3W owners feel better it does have a fault. PDI missed the steering wheel sitting 20 degrees off centre, so we will need to adjust the tracking arms.
And...
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Posts: 125 Likes: 3
Posts: 125 Likes: 3 |
Five wheels? Thats a bit flash!
Posts: 106 Likes: 7
Posts: 106 Likes: 7 |
It took me considerably longer than 3 hours to fit mine! On my mid-2012 body/chassis I struggled with insufficient clearance around the rear chassis lugs which prevented the billet piece from slipping into place. in the end I needed to remove the steering rack to allow a different approach angle. Also, due to the inconsistencies of early chassis fabrication I needed to machine around 1.5mm off the rear of the nearside billet piece. ![[Linked Image]](https://www.tm-img.com/images/2021/11/05/Annotated-nearside-billet-compressed.jpg) After I had the wishbones physically in place it took quite a while to set up the caster and camber angles with careful shimming either side of the rose joints to prevent lateral movement etc, etc. It is definitely an iterative process with each small adjustment seeming to effect everything else! I was fitting new ATR adjustable shocks at the same time which gave me more adjustment but was another variable thrown into the mix. I used a small & inexpensive INCLINOMETER as recommended by Planenut to set the caster & camber and a home-made jig to set the wheel alignment. ![[Linked Image]](https://www.tm-img.com/images/2021/11/05/Alignment-Jig1.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/11/05/Alignment-Jig2.jpg) Having said all this, the whole process has vastly improved the driving experience so I can heartily recommend the kit to everyone. I expect the installation would be much more straight forward for anyone with a later chassis. Thanks for this help!
Posts: 106 Likes: 7
As Bunny confirms, the pre 2014 chassis cars seem not to be built to the same tolerances as the post 2014 cars. I have a 2013 car that had a chassis change in 2015 and have fitted the Empire (now Krazy Horse) Kit to both. The early chassis required several shim washers to get things similar on each side even before we started on the adjustments with the rod ends. When I transferred the Empire Kit to the 2015 chassis it was all much closer and easier to set up. I don't have Bunnies carpentry skills, I just used the clino attached to to steel bits with the magnet and a Gunson Trakrite. The brake disc is handy for wheel angle. The M3W drives really nicely with a well set up Empire Kit and some decent shock absorbers and tyres, all the things Morgan still didn't fit on the final production M3W's  This is good to know. Thank you.
Posts: 338 Likes: 1
Posts: 338 Likes: 1 |
Looks OK Charles nice maroon wheels, not for me though ! Though I bet it's fun to drive ? The spare tyre is going to get very hot with the way the exhaust exits near it ? Each to their own I love Morgan Three-Wheelers faults n all ! Ian
Ian Morgan Family 1929 ( KTW 1100cc ) Morgan S/S 1934 Morgan F4 M3W 2012 Morgan +4 T 1991
Posts: 338 Likes: 1
Andy, I worked out it was far more cost effective given my lack of spare time/facilities to let an expert do the job. Craig displayed an incredible knowledge and great methodology in fitting and subsequent setting up properly my Empire Kit. it was well worth it ! Ian
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I’ve discovered the ground clearance at the front of my car below the tubes that the number plate mounts to is only 110 mm. Furthermore the bell housing reduces that by another 25 mm or so and that’s before I get in! There is a scrape mark where the bell housing has bottomed out on at least one occasion but no other marks on the underside of the car. Is this normal for a 2012 car? To the best of my knowledge it has red spax shocks on the front which appear to be adjusted to their softest setting, with the lower wishbones parallel with the ground. the car is running on Blockleys at 22 psi. Comments, especially with regard to early models would be much appreciated. To answer the OP: My old 2013 was set to 140mm clearance and my new 2021 is 150mm clearance (set by Krazy Horse). Both measured unladen from the bottom of the front number plate carrier and the bottom of the lower wishbone. No problems with ground clearance on either. 110mm sounds too low.
Red Leader
Posts: 33 |
140mm sounds like a lot, and according to google "Most sedan vehicles generally have an average ground clearance between 4-6 inches [about 100 - 150 mm]." Do you happen to know how much lower it gets with driver and driver+passenger?
Noah
