7 members (B3MOG, MJF, Piloto, Rog G, John Winn, RedThree, Graham, G4FUJ),
346
SORN
New
Topics48,368
Posts813,413
Members9,215
Posts: 159 |
Never a dull moment with a Morgan is there - got to admit, I'm loving it.
My latest problem is a small leak around the drainage plug - I've tightened it as far as I feel comfortable and was wondering if anyone has any advice on whether there are safe ways to remedy this.
Is there such a thing as fuel safe plumbers tape for example ? (don't forget I'm still a mechanical novice)
I see there are products on the market but I'd love to get some personal recommendations.
I was surprised when I removed the plug - wanted to make sure it was inserted straight that there wasn't any kind of washer.
Thanks,
Rob
1974 4/4 2 seater
Posts: 2,397 Likes: 14
Posts: 2,397 Likes: 14 |
I'm sure plumbers PTFE tape would work, it wouldn't come into contact with the fuel anyway, probably (?)
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 6,061 Likes: 160
Posts: 6,061 Likes: 160 |
Yep, I removed the drain plug on my GL1000 tank and it started to leak.
I used liquid PTFE/thread sealant as didn't want the risk of thin bits of tape making its way into the fuel system.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 7,944 Likes: 218
Posts: 7,944 Likes: 218 |
Fuel proof thread sealant and similar Dowty washer (as below) under drain plug should sort it. ![[Linked Image]](https://i.ebayimg.com/images/g/4FUAAOSwmWdeZ3F4/s-l1600.jpg)
Posts: 159 |
As always, thank you for your help and great suggestions and another term, 'Dowty washer' added to my vocabulary I decided to go with this permatex 80019 aviation forma-a-gasket No3 sealant in case it helps anyone else.
1974 4/4 2 seater
