7 members (ch44, RedThree, Graham, G4FUJ, B3MOG, KLASG, High Hamster, Soleng),
222
59
Posts837,266
Posts: 150 |
I have a single Tenax (I think) stud on my 4/4’s crash pad. I don’t have a tonneau cover. Why is it there? H
Posts: 2,221 Likes: 180
Posts: 2,221 Likes: 180 |
It's for the tonneau cover you don't have.
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Yep, I have one just off centre for the cover - it doubles up as a fastener for my dash mounted rear view mirror, (Just to the left). Although mine is a 'Lift the Dot' fastener. ![[Linked Image]](https://tm-img.com/images/2022/04/14/274986048_10159637146275049_7759271937656493010_n.md.jpg)
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Yep the tonneau is why it is there & it should be a lift a dot
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Concur. Lift the dot on mine for the tonneau cover. Mine has a single zip so it can be used when only the driver on board. Stud holds the tonneau cover over the passenger area.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Not sure how long it was the norm, but if you didn't order a tonneau cover you didn't get that fastener on the dash top rail.
My 2012 was ordered and delivered like that.
Posts: 150 |
Yes, Lift The Dot; got confused with the naming. As I only have that one I assume I cannot fit a tonneau (if I had had one). Maybe they fit the stud as standard and later fit the rest further down the production line if the customer has ordered one.
A tonneau cover uses the hood fittings on the rear plus a couple of extra studs ( mine are press on poppers) on the doors and on the ends of the “crash pad”.
