1 members (Brian Dearle),
251
42
Topics48,341
Posts812,980
Posts: 150 |
I have a single Tenax (I think) stud on my 4/4’s crash pad. I don’t have a tonneau cover. Why is it there? H
Posts: 2,041 Likes: 71
Posts: 2,041 Likes: 71 |
It's for the tonneau cover you don't have.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Posts: 6,056 Likes: 160
Posts: 6,056 Likes: 160 |
Yep, I have one just off centre for the cover - it doubles up as a fastener for my dash mounted rear view mirror, (Just to the left). Although mine is a 'Lift the Dot' fastener. ![[Linked Image]](https://tm-img.com/images/2022/04/14/274986048_10159637146275049_7759271937656493010_n.md.jpg)
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 26,747 Likes: 419
Posts: 26,747 Likes: 419 |
Yep the tonneau is why it is there & it should be a lift a dot
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
Concur. Lift the dot on mine for the tonneau cover. Mine has a single zip so it can be used when only the driver on board. Stud holds the tonneau cover over the passenger area.
Posts: 21,866 Likes: 167
Posts: 21,866 Likes: 167 |
Not sure how long it was the norm, but if you didn't order a tonneau cover you didn't get that fastener on the dash top rail.
My 2012 was ordered and delivered like that.
Posts: 150 |
Yes, Lift The Dot; got confused with the naming. As I only have that one I assume I cannot fit a tonneau (if I had had one). Maybe they fit the stud as standard and later fit the rest further down the production line if the customer has ordered one.
A tonneau cover uses the hood fittings on the rear plus a couple of extra studs ( mine are press on poppers) on the doors and on the ends of the “crash pad”.
