6 members (How, MartinB60, IcePack, Luddite, TBM, Graham, G4FUJ), 381 guests, and 43 robots.
+8Rich 92
Posts837,279
#738918 14/04/22 01:55 PM
HJF Offline OP
I have a single Tenax (I think) stud on my 4/4’s crash pad. I don’t have a tonneau cover. Why is it there?
It's for the tonneau cover you don't have.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
TBM Online Content
Yep, I have one just off centre for the cover - it doubles up as a fastener for my dash mounted rear view mirror, (Just to the left). Although mine is a 'Lift the Dot' fastener.
Yep the tonneau is why it is there & it should be a lift a dot
Concur. Lift the dot on mine for the tonneau cover. Mine has a single zip so it can be used when only the driver on board. Stud holds the tonneau cover over the passenger area.
Not sure how long it was the norm, but if you didn't order a tonneau cover you didn't get that fastener on the dash top rail.
My 2012 was ordered and delivered like that.
HJF Offline OP
Yes, Lift The Dot; got confused with the naming. As I only have that one I assume I cannot fit a tonneau (if I had had one). Maybe they fit the stud as standard and later fit the rest further down the production line if the customer has ordered one.
A tonneau cover uses the hood fittings on the rear plus a couple of extra studs ( mine are press on poppers) on the doors and on the ends of the “crash pad”.
