4 members (Vansrv6, TBM, Alistair, 1854sailor), 272 guests, and 41 robots.
+8Rich 92
Topics49,839
Posts837,302
Page 10 of 11 1 2 8 9 10 11
Black Rat
Black Rat
Originally Posted by Budster
Originally Posted by Image
How do you deal with where the strap crosses the louvres ? ...... do you cut the protective tape with a razor blade to just cover the 'sticky up bits' while leaving the openi gs clear?
This is a job I will be doing shortly
Aha! Another advantage of having ‘reduced’ louvres, as on my 4/4!
The strap is just forward of the louvres,
happy3
However, I did covet the 70th Anniversary 4/4s which had both the 1.8 Duratec engine and a gap in the louvres, where the bonnet strap sat.
On my 4/4 the mods I’ve added are a Mulfab Al radiator, (many years ago), a wire grille, to protect it, round door mirrors and a wood rim steering wheel.
Bud
4/4 - Stanley
How did Stanley deal with the update hide
Keith
2013 narrow bodied + 4 Ruby.
Goodnight all,
I just bought a Morgan 4/4 from 2010, sigma 1.6l 115hp engine.
What improvements do you think should be made?
My car is already equipped with a stainless steel exhaust line...
Thanks in advance for the advice smile
Lille - France
Plus Four 2024
I'd recommend increasing the number on the odometer as much as possible 🙂
happy3
Bud
4/4 - Stanley
Very well, thank you Keith.
Though it does occasionally suffer light incontinence.
Relieving itself with a few drips of water onto the garage floor.
oldgit
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
Goodnight all,
My first Morgan was one of these and the same colour.
Suggest the wiper blades advertised in Miscellany and Rogers bump stops for starters.
It will need plenty of revs to get any go but just drive it to see what you think.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Hi nestor59310 great looking car clap
If it hasn't been done already I'd upgrade the front suspension.
I had Rutherford suspension and AVO shocks fitted to mine, that was the best up grade I've done, it improved the ride Soooo much happy3
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
4 AVO (Rutherford) and your car will be unrecognizable.
Goodnight all,
If I were you, I would do nothing at the moment. Drive your car, read the fora, join a Morgan club or group if possible, talk with owners, see other cars. Get to know your car, get experience. Then you can decide what you want to change or improve with a good reason. Take your time, think about whether you want to imporve looks, style, function, safety or a combination. Or you might consider the right clothing for you and possibly a co-driver - very important to stay warm and dry. And you might consider the cost/benefit ratio. A Rutherford suspension is fine and functional, but invasive and expensive. Wiper blades are cheap and efficient, but will hardly give you a great advantage if you seldom or never drive in the rain. Clear indicator lenses are cheap and look cool (IMO) but does nothing with the performance.
As I have said before, my best mod that also improved safety - considering cost/benefit ratio - was fitting convex rear mirrors, including the screen one. The best mod - disregarding the cost - was power steering.
If I should suggest something that is easy, cheap, improves handling and not just bling - it would be brake reaction stays AKA crosshead stabilisation stays. But if you wait and drive your car as it is for a while, then you really will appreciate the change once it is there. Take your time.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Originally Posted by Robbie Mathisen
Goodnight all,
Just came to think of it, your car is from 2010, what about the tyres? If they are from 2010 as well, they should be changed. And check your brake fluid, should not be more than two years old. Then check your rear brake cylinders, they have a tendency to get stuck. If your car is bought through a dealer, these things might have been attended to, but you never know.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
On the 1.6 Sigma I recommend the ecu remap with a upgraded air intake. It made a big difference to mine
Craig Jezz
