0 members (),
323
Topics49,844
Posts837,360
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
I see that a number of people (Williams, Allon White, Sifab, Mulfab) offer a lower profile sump for the 3.0 Roadster. Any recommendations?
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
SiFab and Mulfab are the manufacturers. I would probably go to Simon as he's always given me excellent service and workmanship.
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Allon Whites did mine when I bought the car off them. It is essential as otherwise you will hit the sump
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
It is essential as otherwise you will hit the sump John's correct. I did! Mulfab sump fitted as a result. [img][img] https://tm-img.com/images/2022/06/17/2010---201.jpg[/img][/img] Sorry, I always forget which link from TMI to use!
Posts: 638 |
The skid plate is essential. I know of three Roadsters with instant oil loss via cracked sumps - hitting boulder under grass in field/hitting speed bump in roadway/hitting gate stop exiting parking area.
Cheers
David H
Skid plate or an extra 20mm clearance?
There is quite a price difference between the slimline sumps that I came across. Any qualitative differences between them?
Posts: 1,415 |
There is quite a price difference between the slimline sumps that I came across. Any qualitative differences between them? Mine are obviously the best… I supply all the dealers
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
There is quite a price difference between the slimline sumps that I came across. Any qualitative differences between them? Mine are obviously the best… I supply all the dealers PM sent
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
There is quite a price difference between the slimline sumps that I came across. Any qualitative differences between them? I didn't bother with the skip plate on my previous Roadster as it only reduced speed hump clearance, but I did fit the shallow sump from Mulberry, when Simon was there, so he most likely did the welding IIRC Simon crack tests the donors before milling, so you won't get a duff 'un
There is quite a price difference between the slimline sumps that I came across. Any qualitative differences between them? Yes the heart stopping initial drama of hitting the skid plate or something less sacrificial will be the same so best avoided.
