0 members (), 242 guests, and 22 robots.
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,370
Page 1 of 7 1 2 3 4 5 6 7
#744950 17/06/22 11:24 AM
M3W55 Offline OP
I see that a number of people (Williams, Allon White, Sifab, Mulfab) offer a lower profile sump for the 3.0 Roadster. Any recommendations?
M3W55 #744952 17/06/22 11:29 AM
SiFab and Mulfab are the manufacturers. I would probably go to Simon as he's always given me excellent service and workmanship.
M3W55 #744953 17/06/22 11:42 AM
Allon Whites did mine when I bought the car off them. It is essential as otherwise you will hit the sump
John's correct. I did! Mulfab sump fitted as a result.
[img][img]https://tm-img.com/images/2022/06/17/2010---201.jpg[/img][/img]
Sorry, I always forget which link from TMI to use!
M3W55 #744974 17/06/22 03:36 PM
dmh Offline
The skid plate is essential.
I know of three Roadsters with instant oil loss via cracked sumps - hitting boulder under grass in field/hitting speed bump in roadway/hitting gate stop exiting parking area.
Cheers
David H
M3W55 #744975 17/06/22 03:55 PM
M3W55 Offline OP
Skid plate or an extra 20mm clearance?
There is quite a price difference between the slimline sumps that I came across. Any qualitative differences between them?
M3W55 #744985 17/06/22 05:46 PM
Mine are obviously the best…
I supply all the dealers
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
M3W55 Offline OP
PM sent
M3W55 #744988 17/06/22 06:59 PM
I didn't bother with the skip plate on my previous Roadster as it only reduced speed hump clearance, but I did fit the shallow sump from Mulberry, when Simon was there, so he most likely did the welding
IIRC Simon crack tests the donors before milling, so you won't get a duff 'un thumbs
M3W55 #745019 18/06/22 06:23 AM
Yes the heart stopping initial drama of hitting the skid plate or something less sacrificial will be the same so best avoided.
