6 members (Farmershands, Aeromax51, DaveW, piquet, MJF, Paul F), 287 guests, and 73 robots.
+8Rich 80
Topics49,866
Posts837,593
Page 13 of 13 1 2 11 12 13
Looks like a great time. Fantastic photos - thanks for sharing.
Scott
2018 M3W
1995 Porsche 993
Just completed my IoM trip! After spline repairs (and a preventative regulator change) at Phil’s in Lancaster I collected the M3W for a hot drive South (29C in Lancaster, 31C Telford etc) via M6, A49, A41, A44… car back in the garage by 10pm!
Nice one Paul, mine is still undercover in the garage after being delivered by the recovery people the week after. At some point over the winter I will get the engine out and take it up to Phil's in the van for the full mashings conversion.
Hi Paul,
Can you explain your spline repair ?
www.m3w-jungfrau-treffen.com
...After spline repairs (and a preventative regulator change) at Phil’s in Lancaster ...
Hi Paul,
Hi Laurens - my spline was repaired (I believe) per 2) in Phils post on the 5 speeder crankshaft ... Phil did show me there was a slight concave in the S&S spline faces which reduced the contact area! My thanks again to Phil for sorting the fix and spending the time to explain it to me, as well as sorting a quick-fix kit for my old regulator (ie ready to fit!).
Originally Posted by PhilB
2/ if the splines on the shaft are more severely damaged then fit a second undersize hub but filing the damaged shaft splines in order to recover the original shape as far as possible - it should be noted that in this case the nitrided hard skin will be compromised and so a good tight fit is even more important
Paul I’ve send you a PM
