Topics48,347
Posts813,062
Posts: 502 |
Update: received the new clamp and Doughnut from Cain. Supported silencer box, Undid front U-Bolt. It disintegrated !! Undid rear U-bolt . came apart no-problem Pulled exhaust to rear (didn't release rear rubber hanger.) gave sufficient clearance to remove old doughnut, clean up faces. slip new exhaust clamp loosely over manifold down pipe, fit new U bolt over silencer pipe and loosely secure, ( This was a lesson learnt because first time I fitted the new exhaust clamp only to find it made fitting U-Bolt bloody difficult.) Insert new doughnut with exhaust assembly paste. Positioned new exhaust clamp with more exhaust paste and used SWIMBO to put her foot on end of tail pipe and push forward to close two pipes. First tighten forward U Bolt then and secure new exhaust clamp. With SWMBO foot still on tail pipe, secure rear U-Bolt.
Start engine and allow assembly paste to cure.
No Leaks- job done.
But wait! This is a Morgan. Nothing goes completely well and to plan!!
Found that two of the pinch bolts on rubber bobbins had fractured (for a while it appears,)
4 New Bobbins and bolts ordered to finish the job. What was the condition of the donut? Was it rusty and did the two sections separate quite easily?
2004 Series 1 Roadster
Posts: 181 Likes: 1
Posts: 181 Likes: 1 |
Has SWMBO taken her foot off the pipe yet?
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 528 |
Leroy: Doughnut was fairly corroded. Pipe separated easy. Cleaning residual rust and old assembly paste of pipe flares was the longest job. Topline 123: Holy sh*t thanks for the reminder. I will just finish breakfast and then "stand her down"!
Posts: 5,108 Likes: 56
Black Rat Charter Member
Posts: 5,108 Likes: 56 |
My doughnut was so corroded that the pipe was rattling, all came apart easily.
Posts: 502 |
Leroy: Doughnut was fairly corroded. Pipe separated easy. Cleaning residual rust and old assembly paste of pipe flares was the longest job. Topline 123: Holy sh*t thanks for the reminder. I will just finish breakfast and then "stand her down"!  Thanks. Maybe a job for later down the line once I've got the parts needed to replace.
Posts: 7,924 Likes: 217
Posts: 7,924 Likes: 217 |
I deliberately didn't use exhaust paste when re-assembling this joint. After wire brushing flares, donut and inner part of clamp I used copper grease which remains effective to over 1000°C. The parts are free to settle into a gas tight position when tightened up, with less strain on clamp. Joint will also come apart easier later.
Posts: 2,063 Likes: 57
Posts: 2,063 Likes: 57 |
I deliberately didn't use exhaust paste when re-assembling this joint. After wire brushing flares, donut and inner part of clamp I used copper grease which remains effective to over 1000°C. The parts are free to settle into a gas tight position when tightened up, with less strain on clamp. Joint will also come apart easier later.  I used copper paste every time I worked in bike exhaust parts - that means a thousand Times. It saved me hundred of hours when working again on the exhaust!
