Topics48,345
Posts813,038
Posts: 119 |
Curious if anyone's done an automatic transmission swap on a 60's-era +4? Looking to blow the dust off one of our two +4 projects (the '61), and a combination of factors have made the idea of converting it to an automatic a tempting thing to consider.
The car as-is doesn't have an engine or transmission, would likely source the engine from a TR3 block we have sitting around, or possibly the engine from the '66 as that vehicle's got other drivetrain plans. Goal would be a setup that would allow it to keep up with modern freeway speeds.
Posts: 116 Likes: 2
Posts: 116 Likes: 2 |
The size of the bellhousing required for a torque converter might be an issue that requires transmission tunnel mods that impacts footwell and pedal space. There are a couple of 5-speed options that have a history of success. I have one in my '67 +4 that makes freeway speeds much more comfortable. I don't think the tunnel had to be modified at all. One of those conversions might save you some expensive lessons about unintended consequences.
Posts: 119 |
The size of the bellhousing required for a torque converter might be an issue that requires transmission tunnel mods that impacts footwell and pedal space. There are a couple of 5-speed options that have a history of success. I have one in my '67 +4 that makes freeway speeds much more comfortable. I don't think the tunnel had to be modified at all. One of those conversions might save you some expensive lessons about unintended consequences. What conversion did you end up doing?
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
Standard Vanguard had auto transmission an an option, same block as a TR / +4 but rare as hen's teeth I would imagine.
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 116 Likes: 2
Flaagan, Morgan Spares has a conversion kit that uses the Ford T-9 box. That's what's in my car. Reportedly, it's the conversion that requires the least amount of modification. There is a direct link to the install guide on their website, but it appears to be broken. I was able to find the link here. I suggest you give Morgan Spares a call to discuss. I don't know the current situation with availability and pricing, but I'm sure they will let you know.
Posts: 119 |
Flaagan, Morgan Spares has a conversion kit that uses the Ford T-9 box. That's what's in my car. Reportedly, it's the conversion that requires the least amount of modification. There is a direct link to the install guide on their website, but it appears to be broken. I was able to find the link here. I suggest you give Morgan Spares a call to discuss. I don't know the current situation with availability and pricing, but I'm sure they will let you know. Thanks, looking into that as a possibility.
