9 members (RedThree, Graham, G4FUJ, ch44, B3MOG, KLASG, High Hamster, Soleng, TBM, Bitsobrits),
245
61
Posts837,266
Posts: 237 Likes: 1
Posts: 237 Likes: 1 |
Brian Miller and Lionel have both retired John, we both know about Brian but I bought a socket from Lionel only last week!
Dave
2015 4/4 Royal Ivory 2019 Fiat 500C 2019 Volvo V40 T3R
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
OK Dave. Another person on here told me he had stopped. He makes great stuff so this is good news.
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
The Mulfab wheel spanner is a great piece of kit and makes wheel removal a breeze . ![[Linked Image]](https://i.postimg.cc/W3sYFpVz/75808-F17-2-C13-4438-A1-BE-2773-D0-EEA3-F2.jpg)
Kevin Davies
Posts: 81 Likes: 1
Kevin Davies
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
I used exhaust U bolts to bolt that Mulfab tool to a roof rack . Works a treat if all else fails. The photo is the mark 1 version with jubilee clips. ![[Linked Image]](https://www.tm-img.com/images/2021/04/21/20210421_171538.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/04/21/20210421_171544.jpg) Thanks John. This is the direction I was eventually going to take: having moved recently I don't have all those old bits and bobs in the garage that I used to have to adapt and improve on tools.
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 88 |
When my rear spinners seized a local garage extended the standard removal tool with a length of scaffold pole from a skip - worked a treat!
Posts: 1,242 Likes: 30
Posts: 1,242 Likes: 30 |
My wire wheels are always a right difficulty to undo. The reason is simple in that my stainless wires are painted black. The paint has got onto the hub & nut cap. Whilst I have cleaned up the hub contact face, the nut is not so easy to do & I have yet to Dremel clean the inside. There always seems to be a more important thing to do. So far a bit of heat & a scaffolding pole to extend the “ breaker “ bar has worked.
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Can I suggest a dab of brake cleaner. Really softens the paint and makes it a doddle to remove.
thanks TBM, hadn't.t thought of that.
Posts: 309 Likes: 9
Posts: 309 Likes: 9 |
![[Linked Image]](https://www.tm-img.com/images/2020/02/11/socket.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/02/11/socket2.md.jpg) This is available from scparts.co.uk, 01293 847200 It's listed as 'Special tool' for 42mm octagonal spinners, 3/4" drive, part no. 479748. Cost is £48 inc vat ( same as 2018) This has 3 great advantages. No dented wings, ditto wheel rims. The best bit is you can use a torque wrench. I started with 60ftlbs and marked the spinners against a marked spoke. I found only one of the self tightening spinners moved (tighter). At 80ftlbs there has been no movement at all. Why beat the sh*t out of your spinners with a hammer to silly ftlbs when you can easily set them all at a modest torque value and easily get them undone again without the need of a 10 foot spanner?  I know some one will have been using a hammer for 80 years without a problem but we can all have an off day! No finantial interest and no hammer.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
