3 members (jbk, Vansrv6, OZ 4/4),
451
37
SORN
New
Topics48,375
Posts813,542
Members9,215
Posts: 1,674 Likes: 25
Posts: 1,674 Likes: 25 |
Good work GLLOQ! The UK team (me & NippyMog) have been working on a kit that allows a standard Harley V-Rod crank position sensor to be used on the X-Wedge. ![[Linked Image]](https://www.tm-img.com/images/2022/09/07/Bunny_V-Rod_CPS_Kit_3.jpg) It's basically a machined sandwich spacer. ![[Linked Image]](https://www.tm-img.com/images/2022/09/07/Bunny_V-Rod_CPS_Kit_4.jpg) ![[Linked Image]](https://www.tm-img.com/images/2022/09/07/Bunny_V-Rod_CPS_Kit_1.jpg) I hope to offer a kit including the sensor, spacer, extension lead and longer mounting screw. ![[Linked Image]](https://www.tm-img.com/images/2022/09/07/Bunny_V-Rod_CPS_Kit_2.jpg) Initial testing has gone well but I need to put a few more miles on it before being 100% confident. Watch this space!
Andy
Posts: 1,790 Likes: 3
Posts: 1,790 Likes: 3 |
Bunny, do you need the extension lead? The lead on mine is only about a foot long and connects to the loom adjacent to the oil filter next to the regulator multi plug.
Posts: 756 Likes: 9
Posts: 756 Likes: 9 |
Bravo Bunny I think the lack of sensor problem will be solved, I'm also looking at the Mercedes Smart sensor if it is possible to do something with it. I don't have time to drive with the Kia sensor yet. ![[Linked Image]](https://zupimages.net/up/22/36/0tsx.jpg)
Posts: 286 Likes: 22
Posts: 286 Likes: 22 |
Bunny, do you need the extension lead? The lead on mine is only about a foot long and connects to the loom adjacent to the oil filter next to the regulator multi plug. The standard crank position sensor connection plug is located above the starter motor - so I would say yours has been previously modified for some reason?
Bunny, do you need the extension lead? The lead on mine is only about a foot long and connects to the loom adjacent to the oil filter next to the regulator multi plug. The standard crank position sensor connection plug is located above the starter motor - so I would say yours has been previously modified for some reason? Yes, mine is around the starter motor too. Dab of Oppo: I guess you have some kind of interim/development loom? Certainly every CPS I've seen has a long lead.
Andy
Built in December 2012, registered Feb.2013.
The whole 10 year build program was interim/development.
The whole 10 year build program was interim/development.  Mine is older than yours (June 2012) and has the CPS connector in the 'normal' place.
Andy
Posts: 756 Likes: 9
The sensor modify kia hyundai has traveled more than 400 km and works normally.
Posts: 756 Likes: 9
Posts: 756 Likes: 9
