3 members (JMcL, mph, MartO),
109
52
Posts837,276
Posts: 32 |
Can anyone help locate a replacement grommet for a Roadster 2019 washer bottle please, mine has swollen & split so clearly doesn’t like my water.......
80’s J Deere Tractors, Morgan Roadster & 1929 Scott Flying Squirrel
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Likely a generic item. Measure inside and outside dimensions then search for similar on eBay or Amazon.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
You could make your own. I bought some round section O-ring material for a job a while back. Cut to length for the circumference you need and superglue to connect the ends. I have a box of O-rings but none fitted so bought the right diameter( thickness). If I remember correctly it was sold by the metre and not expensive. I’ll see if I can find details. A google search is another way to find some.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Can anyone help locate a replacement grommet for a Roadster 2019 washer bottle please, mine has swollen & split so clearly doesn’t like my water....... From memory they are quite wide in the recess to fit the thick plastic bottle, mine split on my 2018 Roadster & the factory kindly sent a full bottle (under warranty) because it's not listed as separate part You could try Melvyn Rutter, he's good for these daft bits others don't stock
Posts: 32 |
Just for future reference it’s an original Mini grommet, thank you for your help chaps.
Just for future reference it’s an original Mini grommet, thank you for your help chaps. Nigel, this one ? https://www.minispares.com/product/Classic/Grilles_Brightwork/Wipers/Bottles_pumps/BAU2043A.aspx?160503&ReturnUrl=/search/classic/grommet.aspx|Back%20to%20search if correct, that's a great find
As I was passing Mini Sport the other day I picked up this, fyi you can't buy direct from Xpart but both Mini Sport & Mini Spares keep them in stock, just ask for the later SPi & MPi models style of washer bottle ![[Linked Image]](https://www.tm-img.com/images/2022/10/25/Washer-grommet.md.jpg)
Posts: 32 |
Those are indeed the ones, quite a common part when you search.
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
